LH_SP10S006 20180612-1.hexBasic firmware for BMS (you need bootloader firmware to flash the cleaned chip).How to change the main firmware see https://hackaday.io/project/162806-jbd-bms-protocol/log/164283-change-of-firmware. hex - 62.11 kB - 06/04/2019 at 08:23 |
USB_TO_SERIAL_driver.zipWindows driver for working with serial port.x-zip-compressed - 2.17 MB - 12/14/2018 at 10:16 |
User manual for v1.1.pdfAdobe Portable Document Format - 635.63 kB - 12/14/2018 at 09:43 |
JBDTools V1.6-20170622.zipStable program for Windowsx-zip-compressed - 325.18 kB - 12/14/2018 at 09:43 |
LH_communication_protocol.xlsxManufacturer Documentation (incomplete)sheet - 33.76 kB - 12/14/2018 at 09:42 |
