35mm Film Bracket.f3d
Fusion 360 model containing both halves of the film gate/clamp and the mount for my light source.
f3d - 606.35 kB - 12/17/2018 at 02:55
Download
Lower gate.stl
Bottom half of the film gate/clamp
Standard Tesselated Geometry - 201.25 kB - 12/17/2018 at 02:55
Download
Upper gate.stl
Top half of the film gate/clamp
Standard Tesselated Geometry - 132.31 kB - 12/17/2018 at 02:55
Download
Bracket.stl
Adapter for the specific down-light I used. You'll probably want to create a custom mount to use for your specific light source.
Standard Tesselated Geometry - 888.66 kB - 12/17/2018 at 02:55
Download
Light holder.f3d
Fusion 360 model for the down-light case. Unless you're using the same light, this probably isn't useful.
f3d - 85.09 kB - 12/18/2018 at 03:31
Download
light-holder.stl
Case for the specific down-light I used. Unless you're using the same light, this probably isn't useful.
Standard Tesselated Geometry - 103.89 kB - 12/18/2018 at 03:31
Download
Full resolution example scan: Smudge the cat (2002, Kodak Gold 100 ISO)
JPEG Image - 10.30 MB - 12/21/2018 at 08:46
Preview
Full resolution example scan, processed using the Negative Lab Pro Lightroom plugin (2002, Kodak Gold 100 ISO)
JPEG Image - 11.14 MB - 02/13/2019 at 07:43
Preview
Full resolution example scan: Olly the cat (1996, Kodak Gold 200 ISO)
JPEG Image - 8.12 MB - 12/18/2018 at 21:12
Preview
Full resolution "Super High Quality" scan from Wellington Photographic Supplies
JPEG Image - 5.77 MB - 01/11/2019 at 05:47
Preview
Full resolution "High Resolution" scan from Wellington Photo Warehouse
JPEG Image - 8.66 MB - 01/18/2019 at 23:14
Preview
