TelescopeGearingPlate.stl
V1 Gearing Plate - Print 2
Standard Tesselated Geometry - 67.07 kB - 01/20/2019 at 14:29
Download
Pulley100.stl
100 Tooth GT2 -2mm pitch Pulley
Standard Tesselated Geometry - 1.89 MB - 01/20/2019 at 14:28
Download
Pulley25.stl
25 Tooth GT2 -2mm pitch Pulley
Standard Tesselated Geometry - 520.13 kB - 01/20/2019 at 14:28
Download
Pulley20.stl
20 Tooth GT2 -2mm pitch Pulley
Standard Tesselated Geometry - 416.97 kB - 01/20/2019 at 14:28
Download
Pulley100.scad
100 Tooth GT2 -2mm pitch Pulley - SCAD
scad - 18.22 kB - 01/20/2019 at 14:28
Download
Pulley20.scad
20 Tooth GT2 -2mm pitch Pulley - SCAD
Download
Pulley25.scad
25 Tooth GT2 -2mm pitch Pulley - SCAD
Download
TubePivotClamp.stl
Center clamp for the pivot point.
Standard Tesselated Geometry - 204.57 kB - 01/20/2019 at 13:37
Download
TubeSupportRing.stl
Support ring for the paper tube - 3 or 4. For helping to build the tube and support afterwords.
Standard Tesselated Geometry - 104.77 kB - 01/20/2019 at 13:34
Download
TubeSupportJoin.stl
End & Joint Support Ring 2 or 3. One for each end and one for the middle joint (if you have one).
Standard Tesselated Geometry - 107.31 kB - 01/20/2019 at 13:34
Download
First sample pictures
JPEG Image - 334.86 kB - 12/26/2018 at 21:38
Preview
JPEG Image - 215.63 kB - 12/26/2018 at 21:38
Preview
