I will be updating my findings in the logs.
Attempting to reverse engineer an HP 4952A into a general purpose z80 computer capable of running CP/M.
x86 ASM is not a pretty sight. x86 addressing sucks.
So I was banging my head on the wall with reverse engineering the main memory board when I figured "Hey, I have the full schematic of the floppy board, why not just use it as the main processor instead?!" The video hardware is accessible via the J1 backplane so it sure is possible.
I dumped the 256kb rom and was immediately confused. I have never done x86 ASM and specifically chose z80 because the mnemonics make clear sense. The addressing is also linear and straight forward. The x86 machines of the past use a crazy offset system that you were forced to use. Here is a HaD writeup on how it works.
So this board boots to 0xFFFF0 but a 256kb rom is only 0x7FFF so essentially that means the reset instruction is at 0x7FF0. That instruction is EA 65 A4 00 F0 or Jump Far (0xA465 Left shift x4) + 0xF000 which is JMP 0xB3650. Once again we can only address 256kb so and that with 0x7FFF to get an effective JMP 0x3650. Now why is the world didn't they just do EA 00 00 50 36 or even EA 00 F8 50 36?!
EDIT: Upon reviewing the schematics I forgot how the memory was mapped and assumed ROM was at 0x00 like the z80. RAM is 0x0000:0x7FFF and ROM is 0xC0000:0xC7FFF and due to ignoring A15..A17 it repeats at 0xC8000, 0xD0000, 0xD8000, 0xE0000, 0xE8000, 0xF0000, 0xF8000. JMP 0xB3635 still makes no since but it's closer at least.
Well 0x3650 does drop us into a string of subroutines but they mean nothing to me as its all just ex ax xi over and over again. Cutter and IDA are not overly helpful as they can not extract that is code and what is data.
Copy protection or data obfuscation by HP:
I find patches of code that are meaningless and are never called. in the 80c88 there are opcodes that don't exist x86 OpCodes You get a 00 60 00 which is absolutely nothing and does nothing. As its a ROM its not even a placeholder bit for a local variable. I swear that the guys at HP have a random number generator that fills a 256kb file and they or it with their code so all blank spaces are filled with complete garbage for obfuscation.
Get a real serial port or a FTDI Chipi-X line level serial adaptor.
Also get a DB9 to DB25 adaptor or make your own. Pinout:
Get the DOS utilities disk HERE and extract "495XPCUtil_D1.zip" to a DOS directory.
Download / apt-get DosBox
Create a dosbox.conf file in the DOS directory:
[serial] serial1=directserial realport:ttyUSB0 [autoexec] mount C "." C: dir
This will automatically load the current folder as C and display it to you so you know it's mounted.
The serial port may be different for you, I'm on linux with an FTDI adaptor so ttyUSB0 for me.
Now all you need to do is run 5XREMOTE.EXE and you can communicate with your 4952.
1 - Run '5XREMOTE.EXE'
2 - Enter 9600 as the Baud Rate
3 - 'Delete Slave's Application Module'
4 - 'Download Application Module'
5 - 'Execute Slaves Application Module'
If you did a cold boot then you can skip step 3, otherwise you need to delete the old app before you can upload a new one.
NOTE: On linux machine dosbox IS case sensitive. DOS is not case sensitive so its a bit of an annoying issue. When you load your app the interface only allows upper case names and it provides the .APP for you. You need to make sure your programs are uppercase as well as the extention or else it won't find them.
So I figured an interesting place to poke around on was the CRTC (MC6845) as it was well documented.
First I had to put the logic analyzer on the J1 bus to see what IO address was being output. This was challenging as my pinout is not exactly correct. In the end I discovered:
_crtc_wr: equ 0a0h _crtc_wd: equ 0a1h _crtc_rr: equ 0a2h _crtc_rd: equ 0a3h
So I wrote a very terrible asm program that uses the keyboard to modify the 10 registers of interest in the CRTC.
Stock CRTC timing is 32 x 16 @ ~60hz:
I can eek 35 x 32 @ ~28hz:
This as it turns out is not particularly useful as you wrap the address space of the memory's ram and start to display from the beginning again. Also the 28hz is a very noticeable screen flicker. All the garbage on the bottom half of the screen is exactly that, garbage in RAM as the screen is never meant to display that address space.
So an interesting thing to poke at. Maybe when the entire system rom is replaced a larger screen format can be useful. For now, not so much.
Here is what I have been able to piece together of the J1 system bus. AD0-7 and A8-A15 are the multiplexed address and data pins. You can address 64k max directly through the system bus. RD, WR, ALE, IO/M, NMI, IRQ are z80 style pins but there are a few weird unknowns.
The PA0..PA6 are the peripheral select pins after some IO decoding and share interrupts between boards. I only decoded the two.
These pins are from the 4951C drawings. Seeing as the same floppy board is in both machine I would expect the pinout to be the same. Hopefully?
BGRANT
BREQFLP (Bus Request Floppy I assume)
RAMEN / X6
RE
M4
M16
Pin 31
Pin 20
This is a simple little board. Exactly the same as in the 4951C so I have full schematics. This gave me the initial system bus J1 pinout.
Nothing interesting to note other than the fact that the entire card is essentially an SBC. Full 8088 processor with 32k RAM & ROM. The typical WDC floppy controller. There is a custom DMA controller and PIT interrupt generator.
The manual says that this board will load a disk transparently into memory. I assume they mean the "file" that contains the bus data only as there is not enough system ram.
** Very Confused Point **
I have removed the PIO, Zilinx z80, Toshiba z80, toshibas ROM, Postprocessor CPU/RAM/coprocessor, the 8051 AND the disk board is not plugged in. THERE ARE NO MORE PROCESSORS IN THIS THING. WHY DOES IT STILL WORK?!
All the self test fail of course but the hardware tests run an the main menu runs, I can setup the pods menus (nothing actually works of course) but how does the menu system work if there is no processor to handle the keyboard requests?!
I am starting to think the giant PAL/GAL is actually a complete custom CPU. As it shares access to the ROM's I would guess its 8051 based. Once the roms are dumped and I find system code it should be obvious if its 8051 or z80.
This is a very complex board and is at least 4 layers. I didn't expect any multi layer board for a piece of equipment all through hole and from the mid 80's. This would have been a heck of an expensive board to manufacture.
Post-Processor:
We have a ST TS86008 processor with 32k RAM & ROM as well as a custom Hitachi something. The Hitachi chip has only A0..A4 attached so it must be some sort of floating point co-processor or something.
Remote:
When I pop the 8051 out of its socket the self test shows "REMOTE" failure. In the 4951C drawings remote and pod are used interchangeably it seems. If this is indeed to pods processor then the z80 and PIO on the mainboard must just be a serializer. This 8051 must do all the protocol decoding from the raw stream.
RAM & ROM:
This is definitely connected to the 8051 as well as the large GAL in front of the J1 system bus. When I pull ROM 3 the self tests and hardware test interface works but the main system does not load. ROM 3 & 2 and only the self test loads. ROM 3, 2 & 1 and nothing displays on screen. These are 64k ROM's which is also strange as most of the system can only address 64k so each ROM having distinct bits of the system is strange. I will dump them and see what's up.
PIT:
The manual shows the 4951C had a programmable interrupt generator and timer IC. As this is buried in a sea of PAL/GAL's there is no way to know what its actually attached to.
Giant PAL/GAL:
This beast is connected to all the J1 system bus address and data pins as well as the RAM & ROM chips. I would guess its some sort of bus arbiter to act as a kind of DMA between all the system CPU's and the main memory?
On the bottom left we have all the CRT controls. The two AMD chips are presumably dual port RAM chips as the previous several 4951's all used this to eliminate any bus timing issues.
The DLC is not listed on the 4951C schematics but it has its on 32k RAM & ROM.
The Green chips are a z80 and PIO that connect to the pod pin-header. When removed the system still passes the self test so that weird. Apparently the "Remote" processor is the 8051 on the memory board. Maybe this is the capture streaming processor only and just relays data.
I have the repair manual for the 4951C which was the early model of the 4952A. The unit is effectively the same but the main board and memory board are totally different.
The one thing that is exactly the same is the floppy controller board. From this schematic I have verified that all the "double wave" logo'ed ic's are in fact National Semi GAL's. This means the bus decoding is inside the black box and requires probing to identify. That is no simple task.
The floppy board did give me the complete riser pinout though, so from that I at least know the interface. If I can isolate things to similar components I may be able to find a starting point.
This is a dense little board. It has as the standard bits a floppy controller needs like the WD2793A which is the goto chip. The very interesting part is that this board has RAM, ROM aaaaaand a full 8088 x86 CPU.
The 8088 is another one of those weird 32 bit processors with only an 8 bit bus. Makes me wonder if this board all by itself can be turned into an SBC. Heck, with more ram maybe it could run DOS all by itself?
Bus connection ribbon cable leads to TWO strange processors. One TS68008 which is a weird 32bit CPU with only an 8 bit interface. The second is an Intel 8051 CPU. The random 32 bit processor is strange.
I have to wonder if this is not actually the "brain" of the machine and the two z80's on the main board are just for IO and presenting data to the video hardware maybe?
Bunch of SRAM and some card ID selector switches. Also some random LSB/MSB LED's.
Great project, its a pity that there seems no progress since some time.
One addition to your findings from own experience:
The Z0853008PSC on the mainboard is not a Z80 CPU as you wrote. It is the SCC chip (Serial Communications Controller) which drives the POD interface. This chip is better known with its name Z85C30.
There is a single Z80 CPU on this board, it is the Toshiba TMPZ84C00. So menues etc. could work if the Z0853008PSC is removed.
But they should, at first glance, not work if TMPZ84C00 is removed. If I understand correctly what you wrote, it was working somehow with TMPZ84C00 removed. This is really strange, because there is nothing left on mainboard that could run Z80 code. As you also removed all CPU chips from the memory board, it really looks then as if the PAL/GAL chip on memory board named "1820-4838" is executing Z80 code.
I have a HP4952A too, and I have downloaded own (Z80) machine monitor code onto the device. A logic analyzer checks most pins of the Toshiba TMPZ84C00 Z80 CPU. This CPU is executing code when SCC is being accessed. But when just executing monitor commands, with keyboard input and displaying characters, there is no activity on the pins of TMPZ84C00!
So I also think, that another CPU is executing my code, and because my monitor application is written in Z80 code and obviously running on the device, this other CPU must be able to execute Z80 code.
This all leads me to the conclusion that that PAL/GAL is executing the code and does only delegate some sub tasks (SCC access) to the Toshiba TMPZ84C00 .
Maybe you've got more insight on that topic, if yes, please share.
One quick note about what you called the Memory board. That "weird" 68008 32-bit processor with an 8-bit data bus is a 68000 processor with an 8-bit bus. Wonderful processor to work with. That board looks to have its own rom/ram to support that processor. It would be nice to dump those roms too. It would be great if you could post the eprom dumps and some better photos of all the boards. Maybe on github?
Just thinking - have you considered replacing the GAL with your own CLPD/FPGA and setting up the bus to do your own bidding? As an alternative to the headache of trying to reverse engineer what it's doing?
The original goal was a no-mod hack. After quite a lot of reverse engineering I agree but to a larger extent. Pull the entire main board and roll my own z80, mmu, ram, and rom. Just re-use use the video hardware and drive board. Probably won't happen for a very long time though.
Did you get any further with the idea of running an OS on the floppy board and driving the display from there?
I had requested support on identifying a few chips on board and was requested not to publicly publish anything not already in a manual. Unfortunately that makes collaboration very difficult. If someone was to poke around the buss and ID how the memory addressing works we could replace their memory board and DIY the whole thing but even that idea made them nervous.
Do you have the ROMs available for download somewhere?
Any more progress on this yet? Trying to decide if I am going to sell my unit or keep it to follow along with you. 😉
My Digikey order was delivered today so I can make some more progress. I dumped all the PROM's and have replaced them with FLASH chips and am doing some probing with the logic analyzer to identify I/O. I also have a line voltage serial adaptor now so we will see about some code hijacking/injection.
Very cool! Looking forward to seeing how this turns out.
Arrow Westervelt
Bentendo64
Keith
Small update in case anyone else is searching for information on mysterious chip 1820-4838 here: I measured most contacts of that chip, they have same pin numbers as the NSC800. So I ordered a NSC800 CPU, exact type is NSC-800N3I with 2.5MHz clock. And the cool thing is, after replacing the 1820-4838 custom chip with that off-the-shelf CPU, the HP4952A boots and behaves like before. I have not tested much so far, but I suppose that the 1820-4838 is simply a NSC800 with HP product number printed on its case.
