[Ongoing]
Will have 3 center mounted servos controlled by a ESP32s (for future upgrades when I want to connect to Google assistant or make it my assistant). Wire routing and management is going to be hard.
I wanted it to be as proportional to the original one but a lot of other factors like print times and known warping issues with our filament/printer made me squeeze it a little bit. (Lets call it length contraction :p)
Printed it before the holidays in a hurry and as expected, stuff went wrong. Printed the middle servo mount adapters with wrong dimensions. Till the university re-opens and I get access to the printer again, I decided I will get done with the cosmetic part of it.
Starting off with sanding it with 9 levels of grit from 120-3000.
To finish it off, I applied some Meguiar's ultra-cut compound and a Mirror glaze polish and rubbed it with a micro fiber towel. Painted the 'TARS' with a gold-ish acrylic marker. I think I'll stop with the visual part now.
Varshith Solipuram
johnowhitaker
the.wretch
Peter McCloud
How do you plan on making it possible for it to walk? On the movie set it was just carried around by a human walking behind it, who later got removed, because it's impossible mechanically for it to actually be able to walk.
