MIDI controller and synthesizer based on a C-system chromatic button accordion layout.
CBA_MX-cherry.dxffirst prototype cad drawing of mounting plate.AutoCAD DXF - 577.51 kB - 01/09/2019 at 23:25 |
CBA_MX-cherry.dwgfirst prototype cad drawing of mounting plate.DWG Drawing - 91.63 kB - 01/09/2019 at 23:25 |
CBA_MX-cherry.pdffirst prototype cad drawing of mounting plate.Adobe Portable Document Format - 22.48 kB - 01/09/2019 at 23:25 |
36-joystick-vol-envelope-pitch.inoSource code. For the most recent version check out my github repo https://github.com/jonHickam/teensy_chromatic_accordion_synthino - 11.31 kB - 01/09/2019 at 23:25 |
Hey folks, here are a couple more pics.
For the one of the back plate, this is 1/8 steel scrap that I had. I like the patina.
From left to right you have
There is also a close up of the keys, where you can see the round Cherry MX key caps I am using for the buttons. There is not really a pattern to what letters go to what switches other then the C-G in the middle. The black keys are just white keys with sharpie.
You can see how tight I am for space on the back. Im leaning towards making this model MIDI only and building a second prototype with a little more room.
Initial upload and prototype. Features include
Audio Synthesis features
still to do:
Wow, this thing looks (and obviously sounds) great! I'd love to see more build info and pictures. Did you lay out your own PCB for the switches?
You mention you're using MIDI now but adding the audio shield will give you better sound quality, can you explain a little bit? I would think you can get any sound quality you want with MIDI, but the sound shield would make it self contained.
This is really excellent!
Hey Mike,
For the cherry MX switches you can get either PCB or plate mount. I did the plate mount. they are hand wired as a matrix with a diode on each switch. I think PCB would have been easier. You can check out the CAD drawings for the mounting plate in the github repo. I will also get some more pictures up. (all though it is pretty messy looking from the back end right now)
The sounds in the demo are all self contained (not MIDI). The issue is that the digital/audio converter that comes on the Teensy board 3.6 does not handle multiple notes very well. You can hear them distorting in the video. When I add the audio shield I will be able to get better sound quality and do more complicated things with the sounds I am generating, like combining multiple wave forms together (FM synthesis) to come up with a wider array of sounds. RIght now the audio out is either a sine, sawtooth, square, pulse, triangle, or reverse sawtooth wave. You can hear me cycle through them in the demo video.
Hi Jon. This is the best CBA midi controller for practicing that I've seen. The buttons are realistic and spacing is perfect, and 5 rows has more potential than 3. If it's available for under $500 I'd definitely buy one.
