20190203_070022.mp4
MPEG-4 Video - 25.36 MB - 02/06/2019 at 04:43
Download
JPEG Image - 1.27 MB - 02/06/2019 at 04:41
Preview
20190203_070826.mp4
MPEG-4 Video - 47.09 MB - 02/06/2019 at 04:23
Download
IdlerGearPinV2.stl
Standard Tesselated Geometry - 87.19 kB - 01/22/2019 at 02:59
Download
LegGearPinV2.stl
Standard Tesselated Geometry - 325.08 kB - 01/22/2019 at 02:59
Download
WebotLaserV15.1.dxf
AutoCAD DXF - 3.60 MB - 01/22/2019 at 02:59
Download
WebotV15.step
This is the flat pattern for all of the V15 laser cut pcs. The Leg gears need a scan pattern for the countersunk center. Some sew compensation (0.1mm) is needed for the Motor Gear with 0.5mm Module teeth and the code wheel.
step - 9.29 MB - 01/20/2019 at 17:05
Download
WebotRev15 v3.step
Here is what the board looks like after I added some components in Fusion 360. This is the first time I have made an assembled board and it looks very cool. Not sure if the colors will show up in the step file but I added a picture in the log.
step - 5.47 MB - 01/13/2019 at 11:49
Download
WebotRev15.kicad_pcb
Here is the KiCAD layout.
kicad_pcb - 112.10 kB - 01/13/2019 at 11:48
Download
WebotRev15.sch
Here is the schematic for my project. Added a 7805 Voltage regulator to allow higher voltages to run the motor without frying the Wemos
sch - 13.96 kB - 01/13/2019 at 11:48
Download
WebotR12.dxf
This is the laser cut pattern for 2.7mm acrylic. I was able to cut it repeatably on a 50 W laser with 80% power and 10 mm/s speed. All the parts should snap fit together.
AutoCAD DXF - 1.66 MB - 01/11/2019 at 00:31
Download
Here is what the Rev 12 board looks like. The intention was to be able to accommodate 6.5V and 5V. The middle power leg on the input goes through a diode to drop it to a voltage the Wemos can handle while the full voltage goes to the Motor driver inputs to power the motors.
Portable Network Graphics (PNG) - 101.29 kB - 01/10/2019 at 23:59
Preview
