Back to overview
A stopwatch is a handheld timepiece designed to measure the amount of time that elapses between its activation and deactivation.
first make tight and proper connection as per circuit Diagram.For check the working Of 4026 ic i make a monostable counter for testing.
cascade connection of 4x 4026 with 4 x 7 segment display
using Female Header as Holder of 7 segment display
back side
Front Side
add reset , stop and on/off switch
reset pin 15
stop pin 2
it Look Like This
