- working area 1300 x 650 x 200 mm (x/y/z)
- 1050W Kress spindle
- 4,2A NEMA 23 stepper
- ball screws
- supported rails
- completely build from 15mm birch plywood
Bigger, better, faster, fancier. ;-)
The small router is allowed to piggyback onto the new one again. Because it helped so beautifully. :-)
This is looking very useful router specially for me because I am working on a new student removals project that Is just struggling with the current router connection.
Hello, nice project :) I want to ask you some questions about using plywood for machine frame. Are you satisfied with it? Any issues with it? I want to build similar CNC with 1000x700x400 square rails. Would you recommend ply or maybe thicker ply? Any recommendations regarding build? Should I rather invest in some aluminum profiles?
Moin aus Schleswig Holstein
Sehr schönes Projekt!
Wo hast Du denn deine Materialien gekauft?
Und wie genau hast du die Steuerung gemacht?
