In my home every 2 weeks they enter in this modus. It happens because my wall switches are very old.
It’s a pity that so far I didn’t found a way to disable this 3 on/off reset. Anyways it’s very easy with the Mesh app to make them join your network again.
Note: For concrete lamps you need to get it out to make a successful Bluetooth connection. It seems WiFi passes through cement but Bluetooth not so good.
Printed in carbon fiber and built with detail. But with 25 dollars aprox. You can build it yourself! Even with less if you have some spare Leds and an ESP32. Demo Video:
I got some nice messages about the Lamp idea and some requests to make some standard designs. I must say I'm not a great designer in 3D-Modelling and just started doing small things mainly for my own stuff about a year ago.
But anyways since there is some interest I will extend my initial design and make 3 different lines. All based on the fact that most PCB comes with a width of 10 cm:
5*5cm Tiny lamp |_|
10*5cm Rectangular |__|
10*10cm Circular tube (No idea how to cut the PCB but it should be a way)
10*10cm Square-pusher this will hold at least 70 RGBs of 5mm or about 20 of 10mm (From the top of my head)
All ready to be sliced and 3D-printed by you or just to order it so someone else prints it in one of this nice 3D platforms like thingiverse About the LEDs I use standard transparent 5 / 10 mm RGB and some warm white and cold white for some lamps. The cool thing is that is your lamp so you can put inside whenever you like, there are no limitations here ;)
Just keep in mind to separate power from logik with more than 30mA or your ESP32 will warm and possible some GPIOs will need to be buried. Options vary. Will make a dedicated log about this on the next weekends.
