Tray with JLCPCB manufactured tray power distribution board, along with my original prototype tray power distribution board
JPEG Image -
2.39 MB -
12/11/2022 at 17:52
Preview
Main power distribution board
JPEG Image -
2.43 MB -
12/11/2022 at 17:51
Preview
Component side of the charging tray power distribution board up close
JPEG Image -
173.58 kB -
04/23/2019 at 02:51
Preview
Solder side of the charging tray power distribution board up close
JPEG Image -
215.32 kB -
04/23/2019 at 02:51
Preview
Charging tray power distribution boards
JPEG Image -
227.06 kB -
04/23/2019 at 02:51
Preview
I will be using this board in place of the mangled mess that I soldered up for the power distribution on the first try.
JPEG Image -
64.40 kB -
04/14/2019 at 17:08
Preview
Single tray example with all battery cells filled
JPEG Image -
261.44 kB -
04/07/2019 at 03:48
Preview
Single tray example with one battery not installed
JPEG Image -
254.45 kB -
04/07/2019 at 03:48
Preview
Single tray up and running, still need to dress the whole project up
JPEG Image -
276.78 kB -
04/07/2019 at 03:48
Preview
Just a close up of the female spade terminals that fuses will be installed into, but since I had some overlap of the heat shrink tubing covering the opening, I had to trim some of it.
JPEG Image -
240.58 kB -
03/30/2019 at 16:48
Preview
Just another angle of the completed power adapter board prepped to add heat shrink to the female spade terminals
JPEG Image -
333.08 kB -
03/30/2019 at 16:48
Preview
The completed power adapter board prepped to add heat shrink to the female spade terminals
JPEG Image -
318.50 kB -
03/30/2019 at 16:48
Preview
Focused on the 20 female spade terminals that will be used to connect an on/off switch to the power adapter board, to show the heat shrink I put on the spade terminals
JPEG Image -
227.00 kB -
03/30/2019 at 16:48
Preview
Focused on the 2 female spade terminals that will be used to connect an on/off switch to the power adapter board, to show the heat shrink I put on the spade terminals
JPEG Image -
182.62 kB -
03/30/2019 at 16:48
Preview
Another photo of the fasteners and spacers as better described below
JPEG Image -
234.96 kB -
03/30/2019 at 16:47
Preview
I was and still intend to use spacers and these automotive body fasteners (christmas tree fasteners), to hold the ATX power adapter to mount the power board to a shelf but these fasteners are too wide for the holes I had designed/made for this board.
JPEG Image -
238.74 kB -
03/30/2019 at 16:47
Preview
My ATX power adapter board with all the parts soldered onto that I want to use
JPEG Image -
234.51 kB -
03/30/2019 at 16:47
Preview
Test fitting of charging trays 1
JPEG Image -
211.01 kB -
03/24/2019 at 20:33
Preview
Test fitting of charging trays 2
JPEG Image -
252.47 kB -
03/24/2019 at 20:33
Preview
Test fitting of charging trays 3
JPEG Image -
222.52 kB -
03/24/2019 at 20:33
Preview
Test fitting of charging trays 4
JPEG Image -
224.85 kB -
03/24/2019 at 20:33
Preview
Test fitting of charging trays 5
JPEG Image -
223.61 kB -
03/24/2019 at 20:33
Preview
Test fitting of charging trays 6
JPEG Image -
242.82 kB -
03/24/2019 at 20:33
Preview
Test fitting of charging trays 7
JPEG Image -
233.49 kB -
03/24/2019 at 20:33
Preview
Test fitting of charging trays 8
JPEG Image -
233.04 kB -
03/24/2019 at 20:33
Preview
ATX Adapter Pic 1
JPEG Image -
317.60 kB -
03/21/2019 at 02:10
Preview
ATX Adapter Pic 2
JPEG Image -
316.66 kB -
03/21/2019 at 02:10
Preview
ATX Adapter Pic 3
JPEG Image -
203.96 kB -
03/21/2019 at 02:10
Preview
ATX Adapter Pic 4
JPEG Image -
199.16 kB -
03/21/2019 at 02:10
Preview
Gerber_ATX 24 Pin Vertical Layout_20190320215318.zip
Gerber file containing the layout for the SparkFun 24 Pin ATX vertical connector part number: PRT-09497
x-zip-compressed -
3.74 kB -
03/21/2019 at 02:03
Download
Top view of the power distribution board showing the female spade connectors with the fuses installed
JPEG Image -
213.02 kB -
03/17/2019 at 20:04
Preview
Top view (60/30) of the power distribution board showing the female spade connectors with the fuses installed
JPEG Image -
186.14 kB -
03/17/2019 at 20:04
Preview
JPEG Image -
219.39 kB -
03/17/2019 at 20:04
Preview
JPEG Image -
235.90 kB -
03/17/2019 at 20:04
Preview
Just a picture of the positive wires soldered to the power distribution board on the charging tray
JPEG Image -
302.14 kB -
03/17/2019 at 19:54
Preview
Just a picture of the negative wires soldered to the power distribution board on the charging tray
JPEG Image -
308.11 kB -
03/17/2019 at 19:53
Preview
