Arduino based sonar tower
The goal is to make an arduino based sonar tower which scans and displays the direct enviroment.
The goal is to take distance readings from a point and map them to pixels on a screen so a map of the area will be displayed.
To accomplish the goal detailed in the description we had to learn the following:
  • How to control a stepper motor (and driver).
  • How to use a display.
  • How to use the ultrasonic sensor.
  • How to write the code for all of these.
We completed the project itself in 8 hours (485 minutes to be exact).
The final pinout on the Arduino Uno:
Clips made while doing this project:
https://imgur.com/a/M8viiuX
In the end the distance measurements taken by the ultrasonic sensor left much to be desired but by doing multiple measurements for each step I was able to get the precision to a point where I was happy with the result.
SonartorenScript.zip
Final arduino script for the tower
x-zip-compressed - 1.55 kB - 03/05/2019 at 17:00
Download
Tower_Files.zip
3D models for the tower
x-zip-compressed - 1.72 kB - 03/01/2019 at 19:46
Download
SonarPinlayoutTest.zip
A test script with all sensors and actuators
x-zip-compressed - 1.61 kB - 02/13/2019 at 21:09
Download
stepper.zip
A simple stepper script
x-zip-compressed - 709.00 bytes - 02/13/2019 at 19:41
Download
  • 1 × Arduino Uno
  • 1 × TFT screen
  • 1 × Ultrasone sensor
  • 1 × Stepper motor
  • 1 × Stepper driver
View all 6 components
  • Writing the report
    Vincent Dankbaar04/11/2019 at 12:46 0 comments
    Writing the report took up approximately 6 hours of our time. Spread out over multiple weeks whenever we had time.
  • 20-2-2019
    Vincent Dankbaar02/20/2019 at 20:55 0 comments
    Finalised the arduino script for the tower, combining all the previous test scripts.
    Time: 55 minutes
  • 17-2-2019
    Vincent Dankbaar02/17/2019 at 16:55 0 comments
    Used Autodesk Tinkercad to create an adapter for the shaft of the stepper motor.
    Time: 20 minutes
  • 13-2-2019
    Vincent Dankbaar02/13/2019 at 19:17 0 comments
    All the parts for the stepper assembly arrived.
    1 hour: Setup and soldering
    30 minutes: Connecting the parts and running a simple test script
    //Test script
    // defines pins numbers
    const int stepPin = 3;
    const int dirPin = 4;
    void setup() {
      // Sets the two pins as Outputs
      pinMode(stepPin,OUTPUT);
      pinMode(dirPin,OUTPUT);
    void loop() {
      digitalWrite(dirPin,HIGH); // Enables the motor to move in a particular direction
      // 200 pulses = full rotation
      for(int x = 0; x < 200; x++) {
        digitalWrite(stepPin,HIGH);
        delayMicroseconds(1000);
        digitalWrite(stepPin,LOW);
      delay(1000);
      digitalWrite(dirPin,LOW); //Changes the rotations direction
      // 400 pulses == 2 rotations
      for(int x = 0; x < 400; x++) {
      delay(1000);
    The correct color order left to right with the pot on the left side is: Red-Green-
  • Bringing the log up to speed
    Vincent Dankbaar02/11/2019 at 15:53 0 comments
    The project was started before I added it to hackaday, this is our progress thus far:
    4-2-2019, Marco & Vincent, 2 uur, Building distance to coordinate mapping algorithm
    7-2-2019, Vincent, 2 uur 45 min, Converting the algorithm to C++ for the arduino
    8-2-2019, Marco & Vincent, 50 min, Testing the Ultrasone sensor
    9-2-2019, Vincent, 1 uur 30 minuten, Writing a script to make the ultrasone sensor more usable
    10-2-2019, Vincent, 1 uur, Research into stepper motors
View all 5 project logs
Rich text editor
