For evaluation of current weather conditions, it really helps to measure the atmosphere in more than one place. Just one measurement at ground or a bit above will only provide a superficial understanding of conditions.
One of the key measurements I need is windy speed and direction. The most effective method for measuring wind in a sonde situation (where you are moving with the wind) is to measure your displacement. If you drift a certain distance in a certain time, over a certain altitude, the movement of air can be inferred.
I picked up two low-cost GPS modules from Amazon, a BN-220 (~$17) and a GT-U7 (~$15). They were chosen somewhat arbitrarily, since they should all perform similarly. I tested the two units on my bench. This is indoors, so results are probably worse than they would be outdoors. VisualGPSView was used to display the position and GPS performance information. The GT-U7 has an integrated USB port, while the BN-220 requires an FTDI RS-232 to USB adapter to function with a computer. This doesn't really factor into integrated work, but is an interesting note.
Model
BN-220
GT-U7
Networks
GPS, GLONASS, Galileo, BeiDou, QZSS, SBAS
GPS, GLONASS, QZSS
Fix time
15-20s
15-20s
Form
Small, integrated board
Larger board, u.fl connector for antenna
Satellites after one hour
12 used, 21 in view
8 used, 12 in view
Scatterplot
Interestingly, the GT-U7 has a tighter distribution than the BN-220 even with less satellites and a poorer DOP figure. Further tests with the systems outdoors are needed to provide more information, as well as tracking quality under motion.
The idea for this sonde is a minimal cost system that transmits data to ground from at least 5000ft. The device should be recoverable and reusable.
The desired measurements are as follows:
Temperature
Pressure
Humidity
Wind Strength
Wind Direction
P/T/H can be accomplished with a single chip such as the BME280.
Wind measurements can be derived with some accuracy using a GPS and integrating the movement of the system as it falls.
The descent rate of the system will provide the time for GPS movement, but with some caveats; the slower the sonde descends, the more it will drift. A balance needs to be struck between ease of retrieval and measurement quality.
For the first revision I'm planning on dropping them from GA aircraft, but I hope to have them well within drone payload mass and volume. The problem with drone delivery is the limitations on altitude without permits; 400ft is a bit low to collect interesting or useful data to me, but there may be some value.
Interesting - I would have thought there were rules against dropping things from planes. Because if there aren't, I regret not getting my pilots license and outfitting a Cessna with a bombsight!
Although I guess technically cropdusters and parachute planes are dropping things every day...
FAR 91.15: No pilot in command of a civil aircraft may allow any object to be dropped from that aircraft in flight that creates a hazard to persons or property. However, this section does not prohibit the dropping of any object if reasonable precautions are taken to avoid injury or damage to persons or property.
I would consider a parachute and cleared ground as reasonable precautions.
So how will these be going aloft? Weather balloons? Or will they be small enough to be brought to altitude by a drone? Because that would be cool.
