Hackaday.io Hackaday.io
Sign up Log in
ATtiny13 – 8bit mono class D amplifier
This project shows how to turn ATtiny13 @9.6MHz into 8bit mono class D amplifier.
ukasz-podkalickiŁukasz Podkalicki
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2 comments
4 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 2
View Gallery
675
2
4
1
Team (1)
  • ukasz-podkalickiŁukasz Podkalicki
Join this project's team
  • Project homepage
  • Source code
completed project
hardware
attiny13 avr amplifier CLASS D pwm
This project was created on 02/18/2019 and last updated 7 年前.
Description
I always wonder whether it is possible to make an amplifier of class D on ATtiny13 or not. Some time ago I found George Gardner’s project based on ATtiny85 – TinyD. It was a sign to start challenging it with ATtiny13. It took me a few hours but finally I made it! The code is very short and useses a lot of hardware settings which has been explained line-by-line in the comments. The project runs on ATtiny13 with maximum internal clock source (9.6MHz). It gave me posibility to use maximum of hardware PWM frequency (Fast PWM mode).
The PWM freqency of class D amplifiers should be of course much higher, a hundreds of kHz (some sources says 8 times more than sampling frequency). Unfortunately, in case of ATtiny13 it’s not posible to achieve such parameters. However, for experimentally selected settings of ADC sampling rate (~10kHz) and PWM frequency (37.5kHz) the amplifier sounds very good!
Details
Log In/Sign up to comment
Sign up with Github
OR
hackbot wrote 07/18/2019 at 05:54 • point
Inspired by https://hackaday.io/project/19178-tinyd-8-bit-stereo-class-d-amp-from-attiny85, featured on https://hackaday.com/2019/02/12/tiny-amplifier-with-attiny/.
namshang wrote 02/20/2019 at 22:44 • point
Cool! Small, cheap, accepted sound.
Elliptical trainer controlled over WiFi using ESP8266 hosted webApp
Project Owner Contributor
Open Cross Trainer
louis-hLouis H
A simple project that plays any music or tone with Ameba RTL8722DM
Playing Music with RTL8722DM
daphneDaphne
The **ESP32 S3-based PWM Analyzer** measures and displays the frequency, duty cycle, and pulse width of PWM signals in real-time.
ESP32 S3 Based PWM analyzer
nmeth-jzsef-lszlNémeth József László
Official Hackaday Prize Entry
Measure teprature with a crystal occilator, long wave radio and an fpga.
Crystal temp
johannes-wgenJohannes Wågen
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ATtiny13 – 8bit mono class D amplifier", please tell us the reason.
Send message
Remove Member
