Las Vegas of my own!
A 3D printed LAS VEGAS souvenir. It only needs your hand not electricity!
It is the souvenir of my two-month trip to the United States. When I went to Las Vegas to attend CES, I was so impressed of the beauty and splendid of Las Vegas. But the souvenir I saw in Las Vegas was unpretty and not enough to capture the beauty of Las Vegas. So I decided to make my own souvenir of Las Vegas. It's Las Vegas of my own.
I hope the people who saw this souvenir feel Las Vegas.
It's my first gear work for participating 3D Printed Gears, Pullys, and Cams Contest. It looks very easy I know. But to design and modelling was so difficult to me.
If you turn the right handle, all the gears turn. The running man at front doesn't move. The things that move are background surrounding running man. So as you turn handle, you can see the man traveling the Las Vegas!
 There is making process below.
I want someone who makes this feel the Las Vegas or remember the memory of trip to Las Vegas :D
COLUMN.stl
Standard Tesselated Geometry - 16.29 kB - 02/19/2019 at 23:07
Download
main wheel.stl
It's ferris main wheel
Standard Tesselated Geometry - 113.56 kB - 02/19/2019 at 22:38
Download
SPROUT.stl
I used 4 of it to make fountain in front of hotel
Standard Tesselated Geometry - 69.22 kB - 02/19/2019 at 22:35
Download
running_man.stl
It's main character of my work :D
Standard Tesselated Geometry - 78.01 kB - 02/19/2019 at 22:35
Download
LASVEGASSIGN.stl
Standard Tesselated Geometry - 296.47 kB - 02/19/2019 at 22:35
Download
View all 13 files
  • 1 × 3D printer
  • 1 × Glue-Gun
  • 1 × Marker It isn't necessary. If you want to make colorful souvenir, you have to use it!
  • 1
    Print all the files with 3D printer
    All the files except  <main wheel> are printed only once. And main wheel needs to print twice.
  • 2
    Paint it with your own color!
    I painted  <LAS VEGAS SIGN>, <FERRIS>, <HOTEL>. It's because my PLA color was colorful. It's up to you whether paint or not!
  • 3
    Assemble it and stick with glue-gun!
    You first assemble the <BASE_SUPPORT> , <HANDLE>, and<HANDLE_GEAR>.
    Then with <HANDLE_GEAR>  and <BIG_GEAR> fitted, stick the <COLUMN> to <BASE_SUPPORT> with glue-gun. Then fit the <SMALL_GEAR> on top of <BIG_GEAR>
    Then place the man, ferris, Las Vegas sign, hotel, and sprout as you want!
    Very easy but pretty!
View all 3 instructions
perallokes wrote 01/20/2021 at 15:02 point
This project looks so cool and amazing. Can I embed it in my app review site, you can see here https://conversionskitchen.com/loox-shopify-app-review-2021-all-you-need-to-know/
Sophi Kravitz wrote 02/21/2019 at 19:05 point
This makes me feel like Las Vegas! Great project, thanks for posting!
