Jairus of all Iron man Rocket Launcher
I will try to recreate the Iron Man Rocket Launcher by jairus of all
I will repeat , all this is not my design, nor my own invention
Iron Man Rocket Launcher by Jairus of all
So I decided to create this project which is not mine at the base I thank so much jairus of all for this incredible design
it is not a very simple project, it is rather complicated, there is a lot of aluminum part, we do not know the exact dimensions
I'm not going to show you all the dimensions that I could find because it's up to you to look for them and you to try to create it
I'm just going to show you how I managed to find the dimensions
my dimensions may not be accurate it is above all a test
first of all i'm going to watch construction videos
after, I will try to understand how it works
Then I will try to draw
  and after that I will try to make the exact dimension
Plan
Portable Network Graphics (PNG) - 635.77 kB - 02/26/2019 at 11:25
Preview
  • 5 × Kydex / thermoplastic
  • 1 × aluminum plate 1 mm / 1.5 mm thick
  • 2 × Servo Moteur SG 90
  • 1 × multi servo motor tester
  • 1 × J-B Weld
View all 8 components
View all 4 project logs
  • 1
    Watch
    1: watch jairus of all construction videos
  • 2
    Understand
    2: understand how it all works
  • 3
    Draw
    3: draw the different aluminum party
View all 7 instructions
seilerjacinda925 wrote 11/19/2019 at 15:20 point
Hi
Nice to meet you after viewing your profile i am Jacinda, from (jakarta) indonesia,
i have a project discussion with you please email me on: (jacinda.seiler@yahoo.com)
seilerjacinda925 wrote 11/19/2019 at 14:39 point
Hi
DylanDc wrote 02/27/2019 at 09:04 point
welcome on this project :
I thank JAIRUS OF ALL for this amazing design !!!
do not hesitate to ask me questions here:
