1Download pdf : "dimension of all parts.pdf"
it contains all required parts and its dimension. Download it from file section.
2CAD Model of 3D Printer
first, I made the whole model in software, a different part of the dimension of its part is attached in pdf which name is "dimension of parts"
3Building of Whole Assembly
a building of whole assembly for more reference see the YouTube video.
4Setup of Ramps 1.4, Arduino Mega
A connection of different module as per shown images, and for more reference see the youtube video.
5Coding and Slicer,pronterface Programme for a First Print
uploading Arduino coding using marlin firmware, then I download 2 software (slic3er and pronterface) from a net.
6First Print and Result
for first print I choose 25 mm calibration cube and result are as per image for more reference see youtube video.
