For More Details See Youtube Video
In this project, I make a big size 3d printer 400 x 400 x 400 mm for a collage project.
dimension of all parts.pdfAll dimension of required parts and it's quantityAdobe Portable Document Format - 736.21 kB - 02/27/2019 at 09:57 |
Marlin-1.1.x.zipMarlin firmwarex-zip-compressed - 4.71 MB - 02/27/2019 at 10:16 |
Slic3r-1.3.0.64bit.zipSlicer For 3D Printingx-zip-compressed - 26.77 MB - 02/27/2019 at 10:15 |
Printrun-Win-Slic3r-03Feb2015.zipPronterface Softwarex-zip-compressed - 24.13 MB - 02/27/2019 at 10:15 |
Untitled.zip25 mm Calibration Cubex-zip-compressed - 675.00 bytes - 02/27/2019 at 10:15 |
This all video can found on :
it contains all required parts and its dimension. Download it from file section.
first, I made the whole model in software, a different part of the dimension of its part is attached in pdf which name is "dimension of parts"
a building of whole assembly for more reference see the YouTube video.
Recommend a stepping motor especially suitable for 3D printer X axis, Y axis, Z axis, with perfect torque curve:
Type: 17HT19S4200C1
Step Angle: 1.8 deg
Holding Torque: 59Ncm(84oz.in)
Frame Size: 42 x 42mm
Body Length: 48mm
Shaft Diameter: Φ5mm
Shaft Length: 24mm
Shaft D-cut Length: 15mm
https://www.motiongoo.com/index.php?route=product/product&product_id=73&search=17HT19S4200C1
The spare parts are not complete in list there are some missing or its just my confusion
Oh wow, that's some really fine print quality! Good job!
Nice project! I like your heated bed solution.
