For More Details See Youtube Video
In this project, I make a big size 3d printer 400 x 400 x 400 mm for a collage project.
dimension of all parts.pdfAll dimension of required parts and it's quantityAdobe Portable Document Format - 736.21 kB - 02/27/2019 at 09:57 |
Marlin-1.1.x.zipMarlin firmwarex-zip-compressed - 4.71 MB - 02/27/2019 at 10:16 |
Slic3r-1.3.0.64bit.zipSlicer For 3D Printingx-zip-compressed - 26.77 MB - 02/27/2019 at 10:15 |
Printrun-Win-Slic3r-03Feb2015.zipPronterface Softwarex-zip-compressed - 24.13 MB - 02/27/2019 at 10:15 |
Untitled.zip25 mm Calibration Cubex-zip-compressed - 675.00 bytes - 02/27/2019 at 10:15 |
This all video can found on :
it contains all required parts and its dimension. Download it from file section.
first, I made the whole model in software, a different part of the dimension of its part is attached in pdf which name is "dimension of parts"
a building of whole assembly for more reference see the YouTube video.
Recommend a stepping motor especially suitable for 3D printer X axis, Y axis, Z axis, with perfect torque curve:
Type: 17HT19S4200C1
Step Angle: 1.8 deg
Holding Torque: 59Ncm(84oz.in)
Frame Size: 42 x 42mm
Body Length: 48mm
Shaft Diameter: Φ5mm
Shaft Length: 24mm
Shaft D-cut Length: 15mm
https://www.motiongoo.com/index.php?route=product/product&product_id=73&search=17HT19S4200C1
The spare parts are not complete in list there are some missing or its just my confusion
Oh wow, that's some really fine print quality! Good job!
Eviscerate Core
RenierM
DSLR DIY
Nice project! I like your heated bed solution.
