Turn your Makerbot Replicator+ into a full open hardware 3D printer
First, you have to open the back panel of the printer, unplug all the connectors and remove all the electronic parts.
The hot end temperature sensor is a thermocouple with an SPI driver. Although it could be kept, we will use a NTC 100k thermistor because Marlin dosen't support the Makerbot thermocouple driver.
Once removed, place the new NTC thermistor in the hotend cavity and extend the wires if needed (they have to go all the way to the Ramps controller).
The heater cartridge is driven by a MOS-Fet which is located in the smart extruder. All the commands and power pass through the flat cable (that we won't use anymore) which comes from the electronics compartment to the head. With the new configuration we're building, the heater will be driver by the new board (ramps here) which has its own MOS-Fet. So you have to unsolder the cartridge and to sold new wires long enough to go to the electronics compartment.
Now we've got the thermocouple removed and the heater cartridge wires unsoldered (and extended), it's time to get the filament sensor working with the future Marlin setup. Basically, the genuine filament sensor is a simple switch connected to the thermocouple driver via a little board shown below:
Because we got rid of the board it was connected to, we need to solder two wires (long enough to go all the way to the Ramps) in order to use the switch.
Ok we have now new wires coming out of the smart extruder :
You will have to make holes cuts some platic parts oh the smart extruder in order to get all the wires out.
Now it's time to work on the smart extruder dock which houses the extruder motor, the thermal barrier FAN, the blowing FAN and a LED that enlights your printing parts.
What a fantastic tutorial. Thank you for sharing this. I plan to do something similar to my Makerbot 5th gen and will certainly reference this. I just hope it's as easy as you make it seem :)
