Flex PCB design information
Some books and articles to show good flex PCB design practices.
I don't have the time to enter the flex PCB design contest but didn't want the information I have go unused.
If you have questions about flex design and layout, I am happy to help.
I have ideas....
Common-Rigid-Flex-PCB-Design-Flaws.pdf
App Note from EPEC
Adobe Portable Document Format - 5.30 MB - 04/15/2019 at 23:14
Preview
Flex-and-Rigid-Flex-Controlled-Impedance-Design-Tip-Sheet.pdf
App Note from EPEC
Adobe Portable Document Format - 202.34 kB - 04/15/2019 at 23:12
Preview
Minco_FullFlexDesignGuide.pdf
From www.minco.com
Adobe Portable Document Format - 1.64 MB - 03/18/2019 at 15:06
Preview
Flex and Rigid-Flex Design Principles Part1.pdf
Adobe Portable Document Format - 176.51 kB - 03/18/2019 at 15:37
Preview
Flex and Rigid-Flex Design Principles Part2.pdf
Adobe Portable Document Format - 174.18 kB - 03/18/2019 at 15:37
Preview
View all 10 files
View project log
  • 1
    Bend,
  • 2
    Flex,
  • 3
    Repeat..... Not too often!
View all 3 instructions
yegerif381 wrote 05/24/2021 at 07:44 point
very interesting to see this post I like this project and it has some similarities with my new project you can see here https://kiwisearches.com
Boris van Galvin wrote 03/19/2019 at 18:17 point
Some great information thanks. I have a project that requires strips of sensors. Kind of like RGB LED strips except with the LED's removed and sensors put in their place. Any idea who would be the best company to talk to about getting these made? Im going to need about 20 to 30meters of the stuff.
MagicWolfi wrote 03/19/2019 at 22:19 point
Hello Boris, depends on a few things. For professional work Multek or Epec Tech might be a start, they could be able to do this as one piece but it willnot be cheap. For hobby type maker stuff it would be cost effective to use multiple shorter strips and patch them together. This is done often with the LED strips, soldered together on one side and reinforced by adhesive on the other. PCBWay does even online quotes for flex. Out of curiosity I entered 40 pcs 500mm x 8 mm -> less than $200, very reasonable. They even offer an option called 3M tape, sounds like double sided sticky tape, but one would need to check.
Cheers, - W.
(this time I found the reply button\o/)
Boris van Galvin wrote 03/19/2019 at 22:38 point
Thank you for that. I designed the PCB as a 1m strip and it was 8mm wide :)
It just made sense to so it this way as opposed to trying to solder the sensors 100mm apart using wire. I have a feeling that a flexible PCB is going to be a lot more reliable in this case.
MagicWolfi wrote 03/19/2019 at 10:49 point
Awesome, good stuff. Thank you for adding to the list.
