Common-Rigid-Flex-PCB-Design-Flaws.pdfApp Note from EPECAdobe Portable Document Format - 5.30 MB - 04/15/2019 at 23:14 |
Flex-and-Rigid-Flex-Controlled-Impedance-Design-Tip-Sheet.pdfApp Note from EPECAdobe Portable Document Format - 202.34 kB - 04/15/2019 at 23:12 |
Minco_FullFlexDesignGuide.pdfFrom www.minco.comAdobe Portable Document Format - 1.64 MB - 03/18/2019 at 15:06 |
Flex and Rigid-Flex Design Principles Part1.pdfAdobe Portable Document Format - 176.51 kB - 03/18/2019 at 15:37 |
Flex and Rigid-Flex Design Principles Part2.pdfAdobe Portable Document Format - 174.18 kB - 03/18/2019 at 15:37 |
Flex and Rigid-Flex Design Principles Part3.pdfAdobe Portable Document Format - 167.81 kB - 03/18/2019 at 15:37 |
Flex and Rigid-Flex Design Principles Part4.pdfAdobe Portable Document Format - 163.77 kB - 03/18/2019 at 15:37 |
IPC-2223-Design-Standard-for-Flex-and-Rigid-Flex-Circuits.pdfAdobe Portable Document Format - 1.29 MB - 03/18/2019 at 15:37 |
(3a)Happy-Holden(Foxconn)_Impedance.pdfAdvanced discussion about impedance controlled traces on flex layersAdobe Portable Document Format - 5.17 MB - 03/18/2019 at 23:37 |
(3b)Robert-Sheldon(PioneerCircuits)_Impedance.pdfAnother advanced discussionAdobe Portable Document Format - 5.80 MB - 03/19/2019 at 23:09 |
