I have ideas....
Some books and articles to show good flex PCB design practices.
I have ideas....
Common-Rigid-Flex-PCB-Design-Flaws.pdfApp Note from EPECAdobe Portable Document Format - 5.30 MB - 04/15/2019 at 23:14 |
Flex-and-Rigid-Flex-Controlled-Impedance-Design-Tip-Sheet.pdfApp Note from EPECAdobe Portable Document Format - 202.34 kB - 04/15/2019 at 23:12 |
Minco_FullFlexDesignGuide.pdfFrom www.minco.comAdobe Portable Document Format - 1.64 MB - 03/18/2019 at 15:06 |
Flex and Rigid-Flex Design Principles Part1.pdfAdobe Portable Document Format - 176.51 kB - 03/18/2019 at 15:37 |
Flex and Rigid-Flex Design Principles Part2.pdfAdobe Portable Document Format - 174.18 kB - 03/18/2019 at 15:37 |
Rigid-flex PCBs are an interesting mix of both world. Here are some infos, mostly webinars:
EPEC about rigid-flex material and construction
EMA rigid-flex webinar (Youtube)
EPEC Rigid-Flex Circuit Board Gerber Layout Guidelines Webinar (Youtube)
Some great information thanks. I have a project that requires strips of sensors. Kind of like RGB LED strips except with the LED's removed and sensors put in their place. Any idea who would be the best company to talk to about getting these made? Im going to need about 20 to 30meters of the stuff.
Hello Boris, depends on a few things. For professional work Multek or Epec Tech might be a start, they could be able to do this as one piece but it willnot be cheap. For hobby type maker stuff it would be cost effective to use multiple shorter strips and patch them together. This is done often with the LED strips, soldered together on one side and reinforced by adhesive on the other. PCBWay does even online quotes for flex. Out of curiosity I entered 40 pcs 500mm x 8 mm -> less than $200, very reasonable. They even offer an option called 3M tape, sounds like double sided sticky tape, but one would need to check.
Cheers, - W.
(this time I found the reply button\o/)
Thank you for that. I designed the PCB as a 1m strip and it was 8mm wide :)
It just made sense to so it this way as opposed to trying to solder the sensors 100mm apart using wire. I have a feeling that a flexible PCB is going to be a lot more reliable in this case.
Here is other design guide.
http://www.allflexinc.com/wp-content/uploads/2013/10/All-Flex-Design-Guide-Rev-Aug-2013-Master.pdf
celia
very interesting to see this post I like this project and it has some similarities with my new project you can see here https://kiwisearches.com
