Working on a client's project I found the ESP32 a pretty capable chip. I was blown away by the processing power and did some audio experiments with it. The Teensy audio shield didn't fit well and was not satisfying in terms of audio quality so I searched for other codecs out there. Well, this got a little bit out of control and I started this project....
GaryGru
andriy.malyshenko
Geoff McIntyre
Arnov Sharma
Hi Hasan, yeah this would be a really cheap alternative. Probably a little noisier but having everything onboard is pretty tempting. This module even has the 4MB of extra RAM! I should get one of these. Beside the low level stuff, your code port shouldn't be problem.
