Improvement points
04/04/2019 at 12:25 • 0 commentsThe project works well, I would change a couple things for the next version:
- Add a diode or P-Channel MOSFET to avoid inversion of the power supply;
- Change the input connector's silk, the way it is all wires are in front of the text, would be better to see the signals even with the wired hooked up.
