ESPboy easy DIY v3.1
07/17/2023 at 19:07 • 0 commentsESPboy easy DIY v3.1 PCB released and tested.
Works fine!
Now it’s time to make your own ESPboy :)
https://oshwlab.com/espboy/espboy-easy-v1_copy
The MicoJS gamejam has started!
05/06/2023 at 20:33 • 0 comments -
ESPboy tape loader emulator for ZX Spectrum
04/17/2023 at 17:57 • 0 commentsESPboy as a tape loader emulator for Sintez - USSR clone of the Sinclair ZX Spectrum 48k, can be used for any ZX Spectrum. Actualy ported TZX-Duino soft
ESPboy easy DIY released
04/02/2023 at 13:23 • 0 commentsThere have been complaints that ESPboy1 is hard to build for beginners and of course that's my fault, I got carried away with compactness and SMD.
But now I decided to go back to the source and finished a simplified circuit on large and cheap through-holes components.
Now you can buy all a few parts for less than $10 and even a kid can solder them.
It's very hard to go wrong.https://oshwlab.com/espboy/espboy-easy-v1_copy
The compatibility to ESPboy1/ESPboy2 is 99.9% and an extension slot is provided.
So even on this simple device is available ESPboy AppStore, WebAppStore and in general all software and extension modules of the standard ESPboy.
Thanks to @MLXXXp for helping me design and the whole community for their support and inspiration :)
DIY you first own ESPboy!
Have fun :)
Regards, RomanS
ESPboy Meccano Rover
06/04/2022 at 19:12 • 0 commentsSource code: https://github.com/ESPboy-edu/ESPboy_MeccanoRover
ESPboy SegaDreamcastVMU
05/29/2022 at 20:48 • 0 commentsSEGA Dreamcast VMU emulator for ESPboy
source code https://github.com/ESPboy-edu/ESPboy_SegaDreamcastVMU
SEGA Dreamcast VMU emulator for ESPboy project by RomanS www.espboy.com based on Potatochip emulator by SoftVMS by Marcus Comstedt http://mc.pp.se/dc/, ported for Pokitto by Felipe Manga https://os.mbed.com/users/fmanga/code/SoftVMS/
For every game please adjust SPEED_DELAY
In file "flash.h" uncomment one desired game and compile check more games here http://www.bucanero.com.ar/dreamcast/vmu/minigames/ convert to C++ array with web tool https://tomeko.net/online_tools/file_to_hex.php?lang=en
Tests passed for:
- IDOUDO
- ALIENFIGHTER
- POWERSTONE
- SOULCALIBUR
- CHAO_ADVENTURE
- POCKETGT_JP
- POCKETGT
- SAKURA_CLOCK
- SPACE_INVIDERS
- MINI_PACMAN
- PAPER_ATTACK
- SWAMPY
- TINY_TETRIS
- GODZILLA
- RPG
- FREAK_SKATER
Pokitto lib Core ported for ESPboy
05/17/2022 at 19:12 • 0 commentsSource files https://github.com/ESPboy-edu/ESPboy_Pokitto
Now it is possible to compile wonderful Pokitto platform games and apps for ESPboy
ESPboy smart flower waterer module
04/24/2022 at 15:39 • 0 commentsMaybe smart ESPboy flower waterer is a bit overengineered, but it turned out cool
You can set watering intervals and limits on soil moisture, run time, and amount of water supplied. Automatically detects if you run out of water. The RTC3231 alarm clock turns ESPboy on and off, saving battery life. Powered by an external battery, so it's not afraid to leave the sprinkler on for long periods of time. I can add WiFi uploads of all the watering statistics to thingspeak.com, for example, to see on the phone how the watering is going. But perhaps I will add it later. While I'm bored with it)![]()
Amazing ESPboy Youtube review by Retr0rob!
02/15/2022 at 19:18 • 0 commentsAbsolutely amazing review!
It inspires me to push the ESPboy project further! :) -
The great indie console family
02/01/2022 at 16:58 • 0 comments1. Pokitto https://www.pokitto.com
2. ESPboy https://www.espboy.com
3. Gamebuino https://gamebuino.com
4. Arduboy https://www.arduboy.com
Make your choice to play here: https://twitter.com/Retr0Rob :)
RomanS
