The board has been tested using Eclipse and ARM GNU toolchain on MAC. J-Link EDU MINI is used as the debugger.
Schematics, and layout were done in Eagle, and fabricated using OSH Park. The original files are available along with the BOM. Example code (blinky) and import instructions can also be found below.
Sam
XDjackieXD
Bruce Land
