spool-holder.stlA cylindrical spool holder that mounts on the aluminium frameStandard Tesselated Geometry - 48.05 kB - 04/12/2019 at 12:48 |
lcd-supports.stlPRUSA iteration4lcd supports GNU GPL v3 Josef Průša and contributors http://www.reprap.org/wiki/Prusa_Mendel http://prusamendel.org Standard Tesselated Geometry - 270.36 kB - 04/12/2019 at 12:46 |
LCD-cover-ORIGINAL-MK3.stlPRUSA iteration4LCD cover GNU GPL v3 Josef Průša and contributors http://www.reprap.org/wiki/Prusa_Mendel http://prusamendel.org Standard Tesselated Geometry - 693.28 kB - 04/12/2019 at 12:45 |
feet.stlPlastic feet for the printer to stand on. Required unless you use countersunk bolts to fasten electronics on the base.Standard Tesselated Geometry - 411.86 kB - 04/12/2019 at 12:44 |
faceplate.stlA very awesome faceplate that proudly displays "Rosalind".The most important part of the printer :-P Export to amf to preserve the dual colors or set your slicer to print in a different color everything above 2mm (or just color it yourself :-P) Standard Tesselated Geometry - 469.33 kB - 04/12/2019 at 12:42 |
extruder-mount.stlThis file is derived from schlotzz's direct-drive extruder so it's licensed CC-BY-SA 3.0 and not GPL2 as is the rest of Rosalind.It provides a modified extruder drive mount for mounting the geared wade's extruder with mounting holes that fit the frame exactly. There is also an optional filler block that makes sure the motors don't protrude out of the acrylic enclosure. The rosalind has not been tested with this extruder drive. Standard Tesselated Geometry - 65.11 kB - 04/12/2019 at 12:40 |
extruder-drive-direct.stlCompact direct drive bowden extruder for 1.75mm filamentLicence: CC BY-SA 3.0, http://creativecommons.org/licenses/by-sa/3.0/ Author: Dominik Scholz and contributors Using MK8 style hobbed pulley 13x8mm from: https://www.reprapsource.com/en/show/6889 visit: http://www.schlotzz.com Standard Tesselated Geometry - 614.47 kB - 04/12/2019 at 12:39 |
bowden-extruder.stlAssembly for mounting an e3d v6 on the Rosalind in bowden configurationStandard Tesselated Geometry - 2.88 MB - 04/12/2019 at 12:38 |
angle-fastener.stlAngles that mount the frame together. Can be replaced with off the shelf metal fastenersStandard Tesselated Geometry - 774.47 kB - 04/12/2019 at 12:33 |
x-carriage.stlThe part that moves along the x-axis and carries the extruderStandard Tesselated Geometry - 5.25 MB - 04/12/2019 at 12:31 |
x-axis-clamp.stlThe part that mounts the x-axis on the y-axisOtherwise known as the y-carriage Standard Tesselated Geometry - 745.06 kB - 04/12/2019 at 12:31 |
bed-clamps.stlThe parts that clamp the bed frame to the z-axis smooth rodsStandard Tesselated Geometry - 354.48 kB - 04/12/2019 at 12:31 |
leadscrew-nut-clamp.stlLeadscrew brass nut pillow block. The part that mounts the bed on the leadscrew so that it moves when the Z-motor turns.Standard Tesselated Geometry - 73.96 kB - 04/12/2019 at 12:31 |
motor-mounts.stlThis part mounts the x, y and z motors on the aluminium frameStandard Tesselated Geometry - 300.19 kB - 04/12/2019 at 12:31 |
y-axis-clamp.stlThe part that mounts the y-axis rails to the frame of the printerStandard Tesselated Geometry - 311.25 kB - 04/12/2019 at 12:31 |
z-axis-clamp.stlΜounts for the z-axis smooth rods on the frame. Includes mounting space for the z-axis endstop switchStandard Tesselated Geometry - 187.76 kB - 04/12/2019 at 12:31 |
Michael Demetriou
