Operation
All slide switches must be switched to the right for normal operating mode. Connect a 9V DC power supply and the computer will begin running the program stored in ROM.
To program ROM, slide all switches to the left. Connect a microcontroller dev board (Arduino-like) per wiring guidance in the schematics. Code to perform the programming routine is available in my EEPROM Burner repository.
A small utility, hex.py, has been provided to generate the calls to the write
function that are required (in EEPROM Burner) to transfer your binary to the ROM. Create a text file named hex.txt
with hex codes, one byte per line, then run:
python hex.py
The included ROM image, 6502.asm, will capture keyboard input and display it on the LCD screen. This serves as a good template from which to build more complex applications.
Bill of Materials
# | Part Type | Properties |
11 | Ceramic Capacitor | package 200 mil [THT, multilayer]; voltage 6.3V; capacitance 0.1µF |
9 | Electrolytic Capacitor | package 100 mil [THT, electrolytic]; voltage 6.3V; capacitance 220µF |
1 | Electrolytic Capacitor | package 100 mil [THT, electrolytic]; voltage 6.3V; capacitance 47µF |
2 | Electrolytic Capacitor | package 100 mil [THT, electrolytic]; voltage 6.3V; capacitance 22µF |
1 | Ceramic Capacitor package | 200 mil [THT, multilayer]; voltage 6.3V; capacitance 0.01µF |
3 | 74HC08 Logic AND Gate | variant Variant 1; pins 14; chip label 74HC08; editable pin labels false; package DIP (Dual Inline) [THT]; pin spacing 300mil; part # 74HC08 |
3 | 74HCT688E | pins 20; hole size 1.0mm,0.508mm; chip label 74HCT688E; true; package DIP (Dual Inline) [THT]; pin spacing 300mil |
1 | 74LS161A | pins 16; hole size 1.0mm,0.508mm; chip label 74LS161A; true; package DIP (Dual Inline) [THT]; pin spacing 300mil |
1 | 74LS244AN | pins 20; hole size 1.0mm,0.508mm; chip label 74LS244AN; true; package DIP (Dual Inline) [THT]; pin spacing 300mil |
1 | WDC 65C02 | pins 40; hole size 1.0mm,0.508mm; chip label WDC 65C02; true; package DIP (Dual Inline) [THT]; pin spacing 300mil |
5 | 74HC04 | pins 14; hole size 1.0mm,0.508mm; chip label 74HC04; true; package DIP (Dual Inline) [THT]; pin spacing 300mil |
1 | Voltage Regulator | variant sink; chip 78005; package to220-igo; voltage 5V |
1 | 28C256-15 EEPROM | pins 28; hole size 1.0mm,0.508mm; chip label 28C256-15 EEPROM; true; package DIP (Dual Inline) [THT]; pin spacing 300mil |
1 | CY7C199-35PC SRAM | pins 28; hole size 1.0mm,0.508mm; chip label CY7C199-35PC SRAM; true; package DIP (Dual Inline) [THT]; pin spacing 300mil |
4 | 74LS32 | pins 14; hole size 1.0mm,0.508mm; chip label 74LS32; true; package DIP (Dual Inline) [THT]; pin spacing 300mil |
1 | LCD screen | pins 16; type Character |
2 | NPN-Transistor | package TO92 [THT]; type NPN (EBC) |
2 | 10kΩ Resistor | tolerance ±5%; resistance 10kΩ; package 2512 [SMD] |
2 | 5kΩ Resistor | tolerance ±5%; resistance 5kΩ; package 2512 [SMD] |
5 | 3.3kΩ Resistor | tolerance ±5%; resistance 3.3kΩ; package 2512 [SMD] |
1 | Pushbutton | package [THT] |
5 | 74HC595 | package DIP16 [THT]; type 74HC595 |
13 | SWITCH_SPDT | package kps-1290 |
1 | POT | variant 100k_3362u; package 3362u |
1 | mini DIN 6 Connector | variant pth; package mini-din6; connector Mini-DIN6 |
1 | Crystal | frequency 1 MHz; package THT; type crystal; pin spacing 5.08mm |
Hmm, strange, I created it in 0.9.3, and have opened it on both Ubuntu and OS X. I've had some other people that I know have also opened it, so I think the file is good. What exactly is happening when you try to open it?
Sorry you're having trouble. I'll take a look later to see if there's anything I can do.
