vm02.rar
Full offline version
RAR Archive -
4.83 kB -
05/25/2019 at 10:56
Download
vm01.rar
Hardware test code
RAR Archive -
3.12 kB -
04/22/2019 at 13:46
Download
Vending Machine v102.f3d
Fusion 360 file
fusion -
19.55 kB -
04/21/2019 at 18:55
Download
Vending machine shield_2019-03-28.zip
Gerber file, ready to manufacture the PCB. File tested and 100% functional.
x-zip-compressed -
315.90 kB -
04/21/2019 at 18:51
Download
6mm-mdf-pg1.svg
Vector file compatible to Inkscape from 6mm mdf cuts, pg1. Sheet size is 40x80cm
svg+xml -
63.39 kB -
04/21/2019 at 18:46
Preview
3mm-clean.svg
Vector file compatible to Inkscape from 2.8mm acrylic cuts. Sheet size is 40x80cm
svg+xml -
52.37 kB -
04/21/2019 at 18:46
Preview
3mm-mdf.svg
Vector file compatible to Inkscape from 3mm mdf cuts. Sheet size is 40x80cm
svg+xml -
43.82 kB -
04/21/2019 at 18:46
Preview
6mm-mdf-pg2.pdf
Pdf file from 6mm mdf cuts, pg2. Sheet size is 40x80cm
Adobe Portable Document Format -
1.81 kB -
04/21/2019 at 18:46
Preview
6mm-mdf-pg2.svg
Vector file compatible to Inkscape from 6mm mdf cuts, pg2. Sheet size is 40x80cm
svg+xml -
16.10 kB -
04/21/2019 at 18:46
Preview
6mm-mdf-pg1.pdf
Pdf file from 6mm mdf cuts, pg1. Sheet size is 40x80cm
4.74 kB -
04/21/2019 at 18:46
Preview
3mm-mdf.pdf
Pdf file from 3mm mdf cuts. Sheet size is 40x80cm
4.74 kB -
04/21/2019 at 18:46
Preview
3mm-clean.pdf
Pdf file from 2.8mm Arylic cuts. Sheet size is 40x80cm
2.55 kB -
04/21/2019 at 18:46
Preview
Vending machine shield.pdf
Pdf schematics file
49.57 kB -
04/21/2019 at 18:45
Preview
Vending machine shield.sch
Eagle schematics file
sch -
1.05 MB -
04/21/2019 at 18:43
Download
Vending machine shield.brd
Eagle board file
brd -
207.63 kB -
04/21/2019 at 18:43
Download
