Perfore el tube de pegamento para que entre el led en cada extremo.
![](https://cdn.hackaday.io/images/4486851555878944474.jpg)
Then insert the glue stick with the led into the soda lid.
![](https://cdn.hackaday.io/images/2128171555879111140.jpg)
Join all the GND contacts in one wire; a join the positive contact of the led's of each segment.
I don't use a 74hc595 to control the led's, because a don't have four of them right now, instead i use a MC23017 to control the 7 segments.
The circuit is really basic:
![](https://cdn.hackaday.io/images/6804961555879406359.jpg)
The schematic is this
![](https://cdn.hackaday.io/images/7580581556117453027.png)
On the MCP23017 the pin's number 1 to 8 and 21 to 28 will be connected to the leds.
A very cool way of using these 'resources'..
Thanks for sharing!
