Tomodachi X2
A modern retro system, compatible with the C64, C128 and MSX2+.
As the number of still working Commodore 64 & 128, MSX, Sinclair and Atari systems dwindle, there is still a lot of demand for such systems, both by those who used such systems back in the 80s and 90s, and those who have discovered such systems later on.
The Tomodachi (友達, or 'friends' in Japanese) X2 project intents to capture all that makes such retro systems so attractive to use along with all of the nostalgic bits, while adding a dose of modern electronics that nevertheless should not get in the way of enjoying all the good that 8 and 16-bit systems had to offer.
Along with hardware 6502 and Z80 compatible processors and integrated C64, C128 and MSX2+ modes, the Tomodachi X2 system can also be used as its own multi-processor, multi-architecture system, with many interfaces including PS/2, Ethernet, serial & parallel, 3.5" floppy drive support, a Yamaha OPL3 synthesizer chip, high-resolution graphics and much more.
The project's PCB is being designed in KiCad, with a custom enclosure in progress that will fit the custom PCB form factor. At this point in the project's development the specifications are:
  • W65C816 MPU (x2)
  • eZ80-190 MPU (x2)
  • MIPS soft core (in FPGA)
  • 256+ MB of DDR3 SDRAM
  • "Alice" chipset.
  • Yamaha OPL3 synthesizer
  • Commodore 8580 SID (x2)
  • Commodore 6581 SID (x2)
  • 100 Mbit Ethernet
  • SD card reader
  • Parallel port (SPP, EPP & ECP)
  • RS-232C port (x2)
  • DVI output (VGA compatible)
  • Stereo audio out, microphone input
  • Single 3.5" floppy drive
Current status:
  • Developing the "Alice" chipset using a Lattice ECP5-based development board.
  • Case design mock-up has been completed.
  • Sampling a number of (Microchip) Super-I/O ICs (SCH5027, SCH5627) that are 3.3V & LPC compliant.
  • Board layout and schematic are progressing into the final stages before review.
  • New case design and setting a schedule
    Maya Posch • 08/28/2019 at 19:18 • 0 comments
    With the PCB I/O layout close to being finalised, a mock-up of the case for the system was created that should give some idea of what the final product should look like:
    Rough dimensions for the case are: 340x190x120 mm  (WxDxH). The final look will likely differ from these preliminary renders, but it should give some idea of what to expect there. The 'Legend of Nyan' MSX cartridge is not included with the final product (unless sponsored to become a real game, of course).
    Alice update
    Sharp eyes may have noticed that the specifications for "Alice" have been changed slightly. The internal communication bus has been firmly set to be AXI4 (AMBA 4), with the internal CPU core being the Plasma, MIPS I-compatible core which is currently being ported to ECP5 FPGAs. While some may lament the loss of RISC-V as a feature, this change should provide the fast prototyping and stable development toolchain that the project can use to get it finished.
    Remaining schedule
    Barring any major setbacks, next month should see the integration of the individual parts of Alice, followed by the integration of the Super-IO chip and other components external to the FPGA. This will initially be done on breakout boards to ease development.
    Following this, the schematic for the PCB will be finalized for prototyping. This should happen later this year, with possibly final integration and assembly testing following before the end of the year. That should conclude the PCB development and with it most of the FPGA core development.
    Finally, next year should see the development of the final case design, the integration of the PCB and the progress towards towards actually getting the whole package produced, the progress of which will most likely depend on the demand and the resulting budget.
  • Progress Report #1: Optimism
    Maya Posch • 08/18/2019 at 11:37 • 0 comments
    As they say, the best way to do a project is to head into it with overflowing amounts of enthusiasm and a vague inkling of how all the bits and pieces will actually fit together. Or maybe that was actually about how not to start a project. Regardless, after many hours of bashing away at the Tomodachi X2 project, something resembling an actual product is beginning to emerge, like a beautifully refined sculpture being carved from a shapeless piece of rock.
    At the onset of the project it wasn't quite clear which compatibility modes would be added. This has now been solidified into the Commodore 128 and MSX2+. The former also gets one Commodore 64 and CP/M mode. The latter gets one the whole range of MSX systems, barring the MSX TurboR, which uses a different processor altogether.
    Biggest progress on the physical system has been the work on the schematic and PCB layout, which has led to the current 250x170 mm board and its connectors:
    This connector layout has been selected to merge both the connectors for the RISC-V system and the Super-IO chip, as well as those of the Commodore 128 and MSX2+. The latter will have to use the C128's tape drive and the Super-IO's printer port via a bridge in the chipset to make them compatible. This means that physical MSX tape drives and printers are not directly supported, but would require external hardware to convert the signalling to the appropriate format for those devices.
    These decisions were mostly made to support the most commonly available hardware, and to limit the number of physical connectors on the board. Even at its current size it's already a fairly expensive board to have produced.
    Alice chipset
    The Alice chipset now features at its core a RISC-V processor, which forms part of the native TX2 mode. It coordinates the configuration of the system, and allows the other modes to be enabled. This part of the system is currently being prototyped on an FPGA development board, with the external processors, Super-IO chip and further hardware being added as needed on breakout boards. This approach should hopefully speed up development.
    Custom enclosure
    With abandoning the mini-ITX form factor and going for a custom form factor, this meant that while existing cases could not be used any more, we could however design a case that is specific for the TX2 system. This offers quite a lot of possibilities.
    Later this month we hope to get some preliminary renders of this case online, to give an impression of what one might expect.
  • Let the development commence
    Maya Posch • 06/25/2019 at 16:03 • 0 comments
    Over the past weeks/months/too much time, I have been primarily occupying myself with the details of the "Alice" chipset, as this is the magic sauce that will make Tomodachi X2 either awesome or not so cool. Details such as how to switch between system modes, how to make everything flexible enough that one isn't limited to just a handful of options, and maybe most importantly of all, what 'native Tomodachi mode' is all about.
    While brainstorming about this both by myself and with some friends, it quickly became obvious that while one could totally use one or more of the hardware CPUs on the board for native mode, it would be easier and much more powerful to use a more modern architecture. That's when picking a RISC-V core came into the picture.
    These cores are nice and small, with some taking up only a few thousand LEs on an FPGA like the ECP5. Meanwhile they are efficient (depending on the core in question, of course) and very flexible due to the RISC-V architecture. This led to us poking at a number of cores, including f32c, Rocket and a funky one called Potato. Depending on which of these are the least painful to use, and with a strong preference for VHDL will ultimately decide which one will be featured on the first functional TX2 prototype.
    Best thing of course is that since they all use the RISC-V ISA, switching cores later on is totally cool, as the software will still run.
    As for the architecture of the chipset itself, it'll likely end up looking somewhat like this:
    Using a crossbar switch fabric to tie relevant elements together, and likely splitting mode-specific peripherals (such as the C64 PLA, ROMs and CIA chips) into their own modules should provide maximum flexibility. Meanwhile the SDRAM controller (DDR3 or otherwise) would be designed to accommodate different modes, such as 16- or 24-bit addressing, even allowing each MPU to have its own dedicated block of RAM, up to 64 kB or 16 MB.
    As far as mode selection goes, one might be reminded of the C128, where one had to remember in which mode one was, followed by performing the required ritual steps to boot into the other mode: C128 manual.
    Here a thought is to either boot into native mode, and execute a command there that will perform the switch, or have physical switches (hooked up to the bootloader in the FPGA) that can set the desired mode before one powers up the system. Perhaps a tad Altair 8800-ish, but could be useful if one intends to use the system in a specific mode for an extended period of time.
  • Settling on a first prototype design
    Maya Posch • 05/10/2019 at 09:27 • 0 comments
    The Tomodachi project isn't a new one. It's something which I have toyed with in some form or another probably since the 1990s. What is new is that for the first time I have decided to put my love for those old home computers and modern technology together to make a system that is practical to make (now and during the coming years/decades). It should also cover all of the points that made systems back then so much fun to use, while not shying away from new technologies that enhance the experience instead of taking away from it.
    After months of brainstorming, the design that I came up with is basically the following:
    I have had people comment on this diagram with 'it's basically a Commodore 128!', which I think is fair enough. It has the same 6502 compatibility (in the form of the 65C816) and CP/M-via-Z80 compatibility as the C128, though it ups the game by having the 16-bit successor to the 6502, as well as the modern, pipelined version of the Z80.
    Also, it has two of each MPU, with the chipset providing access to the full range of DRAM, meaning 16 MB of RAM per 65C816 and eZ80-190 and DMA possible between these RAM segments as well as peripherals. Because there should be peripherals. From a floppy drive (obviously), to Ethernet (100 Mbit at least), to a range of synthesizer chips (Yamaha OPL2, stereo SIDs), as well as LPT (parallel) and COM (serial) ports.
    Video isn't drawn explicitly into this diagram, but will be integrated into the chipset, with both VIC-II compatibility as well as its own, 1080p (or better) capable video adapter, outputting video likely via DVI-I (digital & analog output) and DisplayPort.
    At this stage a Mini-ITX compatible board layout is being targeted, with the schematic and board layout gradually being finished for the first prototype board. All of this is done in KiCad, naturally. For the chipset an FPGA will be used, with the Lattice ECP5 (without SERDES) being a likely target. Much like the PLA in the C64, it's this chipset that will be the 'magic sauce' that makes the whole system work.
    After initial prototyping, fun details such as which shell to use will pop up. Clearly, the system should boot from ROM like the C128 and C64 for that 'instant on' experience. Whether one would use a BASIC shell of some type, boot into a DOS, or use a Forth shell (why not?) is all still up in the air.
    My hope is that others will feel interested enough in this project to pitch in, even if it is just with some ideas and sketches on the back of envelopes, scanned in and faxed to me. It's going to be fun, I'm sure :)
View all 4 project logs
Joan Carles wrote 11/23/2019 at 16:21 • point
Hi
I think it's a very good project,? What state is it currently in? Are there any dates for completion, sale, etc.?
regards
Raffzahn wrote 09/05/2019 at 20:24 • point
What a lovely project. In fact, it's somewhat related to a project I do as well fancy since *many* years (>30): What would have been if the 6502 had evolved instead of a basic stand still since 1976. I'm as well in a phase to turn it into more than a few scribbled napkins.  It may be a nice idea to use your 'Alice' as well. So a few questions arise:
a) Design of the protocol (signalling) at the CPU/crossbar interface (it really needs a name of its own) ?
b) How is clock synchronues operation handled (Timing loops etc.)
c) Would it be capable to handle more than 24 address lines?
d) Can it accommodate multiple address spaces (like Z80 I/O or Video)?
e)  (Subquestion to a) What is the protocoll for interrupt/messaging
f) Are there facilities for inter processor communication defined (beyond interrupt exchange that is)
Unrelated, but maybe as well interesting
g) Any plans to add an FPU/DSP core to support the 8 bit CPUs?
h) With a MIPS core, wouldn't it be easy to replace the SIDs by a software emulation (invisible for the 8 bit CPU) to save the need of getting a pair? Like having just a bit of VHDL emulating registers, but let the MIPS core do the rest?
Sorry if that's too much at once.
H.
AVR wrote 06/25/2019 at 17:24 • point
love the idea of this and looking forward to your progress! Might be interesting to me as a synth platform since you are including the SIDs and the yamaha chipset all in one board.
Maya Posch wrote 06/26/2019 at 14:41 • point
Thank you for your interest! :)
That's indeed another interesting thing that TX2 could be used for, yes. Depending on user feedback, other chips might also be included. So far I settled on the most popular chips, but it's by no means the final list.
The OPL4 is another one which seems interesting, as well as other chips from that era.
AVR wrote 06/29/2019 at 02:49 • point
I think you got a great set of chips already one or two wouldn't hurt lol, maybe an AVR with some sort of wacky open source soundcard like firmware IDK, just to add yet another layer to it all lol.
