Micro generator platform for water and wind energy
Open low power motor controller platform for generator applications
Project describes the development of an open brushless controller platform dedicated for low power energy conversion applications.
Platform is based on a well-known VESC Project, which provides a good starting point for projects related to motor control. Modifications to the embedded and PC software as well as hardware will be presented which will allow for standalone generator operation.
Goal of the project is to provide and inspire new open solutions in the field of energy conversion, either in the form of the whole system, control strategy, firmware, hardware or development/testing concept.
Controller is being designed with three specific operating topologies in mind.
Current state:
We have a working software for the 1.) and 3.) topology.  Next, custom HW design and software support for 2.) topology is planned.
1.) Generator is connected to a battery
Motor controller shall run a MPPT algorithm, control charging, reduce power consumption when energy conversion is not possible.
2.) Generator is connected to a grid tied micro inverter
Motor controller shall emulate a U/I load that is compatible with micro inverter MPPT algorithms.
3.) Generator is supplying a low voltage grid
Motor controller shall regulate voltage on the DC voltage grid.
Embedded SW for motor controller:
Controller can operate in different modes according to the above requirements. For motor/parameter setup existing VESC capabilities and documentation can be used.
MODE 1: MPPT + battery charging
Simple and predictable MPPT scanning algorithm was developed. Parameters can be adjusted to fit different applications (scanning time, current/torque step, maximum current, MPP timeout, starting speed etc.).
Based on the battery voltage charging current is derated at full state of charge (with adjustable voltage gap and full battery voltage).
MODE 2: Voltage regulation to support U/I curves
Voltage on the output of the motor controller is regulated by constantly adjusting motor torque. Output voltage/current curve can be parametrized to support external MPPT tracking from the grid tied inverter.
U/I curve can also be parametrized to support a constant DC voltage source within the capabilities of the mechanical energy source.
MODE 3: Simulation of rotational energy source
A simple mechanical energy source is modeled that reduces rotational speed with increasing torque (with adjustable coefficients). This mode can be used to test different generation algorithms on a back-to-back setup (two motors and controllers mechanically coupled with a coupling).
SW for PC GUI application:
Generator mode is integrated into the existing VESC GUI application. Different generation modes and parameters of the controller can be configured.
Hardware design:
A variation of low power (<50 V 1000 W) motor controller and mechanical enclosure will be proposed with improved thermal and environmental performance. A contactor on the DC link will be added to reduce current leakage when motor is not generating power. Software will still be fully compatible with existing VESC based motor controllers.
System sizing instructions:
Template for motor/controller sizing based on the system requirements will be prepared.
  • DC supply voltage control
    Mitja Breznik05/12/2019 at 12:44 0 comments
    I have decided to first develop a simple DC supply voltage controller that will be the basis for two configurations described in the introduction (controller acting as a voltage source for the self sustained DC "grid"; controller connected to the grid-tied inverter).
    Controller is a simple PI regulator that determines the motor torque based on DC voltage reference and measured DC voltage:
    Parameters are currently set with experimentation, but there should be a simple way of defining the coefficients based on system parameters (capacitance, torque constant, rotational speed).
    For the "proof of concept" test I used a simple power resistor as a load for DC supply:
    Voltage reference was set at 15 V (voltage controller running at 1kHz), while resistor was connected and disconnected multiple times. Voltage remained constant while the motor current changed according the the DC supply energy demand:
    Here is a video of the multimeter  and power resistor connected to the controller DC terminals:
    After some additional testing I will add the support of the new mode and parameters to the PC GUI.
  • MPPT scanning algorithm test
    Mitja Breznik05/05/2019 at 09:24 0 comments
    Simplest way for me to test different energy conversion functionalities is to build a back-to-back setup. I have coupled two brushless outrunners enclosed in a plexiglass tube for protection. It is not the optimum solution for long term testing, due to heat build-up, but it will suffice for SW testing.
    Instead of connecting the generator side of the system to the wind or water turbine I programmed a simple linear speed/torque curve to one of the motors:
    set_speed = no_load_speed - ramp_coefficient*motor_current
    Parameters of the load curve can be adjusted with a PC GUI. Linear load curve should have a maximum power point at no_load_speed/2. Wind or water turbines tend to have higher order load curves but this simple curve is sufficient for first tests.
    I have programmed a simple MPPT algorithm, that measures the generating power over the whole pre-programmed range and then settles at the MPP:
    All parameters can be set of the PC GUI application with the modified VESC Tool:
    Number of different parameters should ensure that SW could be adapted to a number of different generator applications.
    Here is a screenshot of the motor currents/speed during the first MPPT test:
    In order to use this algorithm to charge the battery there is feature added which gradually reduces the charging current until reaching full battery voltage.
    I will perform the next MPPT test by connecting the generator side to the LiPo battery pack and test the full battery derating function.
View all 2 project logs
Sven Ruin wrote 07/06/2024 at 10:29 point
I'm planning to do something similar and would be interested to hear if there has been any more progress in your project?
Marcos wrote 07/28/2019 at 14:14 point
Hi, did you clone the vesc repositories or just copied the files? If you didn't clone you can't merge your changes into the mainstream VESC.
