Order the Lipo battery, EDF fan, ESC, servo tester if you also want to test the EDF before your controlling circuit is ready. Maybe also a lipo battery tester so you can double check if your circuit works as intended. Don't forget to order Lipo charger, XT 60 or XT 90 adapters (male and female), so you don't have to order other things in a separate order after you received all the things, and notice you have missed something! (as I did)
2
(V1 and V2) OPTIONAL: Dynamically balance the EDF unit with your cellphone
I did not do this step, but it is really recommended to reduce noise and improve performances and battery duration.
