Harmonic1-15Ver1.stp
stp -
4.25 MB -
05/25/2019 at 17:24
Download
Harmonic1-21Ver1.stp
stp -
5.30 MB -
05/25/2019 at 17:23
Download
CircularSpline1-21.stl
Standard Tesselated Geometry -
756.53 kB -
05/25/2019 at 17:22
Download
FlexSpline1-21.stl
1.15 MB -
05/25/2019 at 17:22
Download
UpperCover1-21.stl
308.68 kB -
05/25/2019 at 17:22
Download
EllipseDrive1-21.stl
817.66 kB -
05/25/2019 at 17:22
Download
UpperMount1-21.stl
292.86 kB -
05/25/2019 at 17:22
Download
LowerCircular1-21.stl
255.55 kB -
05/25/2019 at 17:22
Download
LowerMount1-21.stl
388.17 kB -
05/25/2019 at 17:22
Download
FlexSpine1-15.stl
830.75 kB -
05/25/2019 at 17:21
Download
EllipseDrive1-15.stl
775.86 kB -
05/25/2019 at 17:21
Download
UpperCover1-15.stl
320.59 kB -
05/25/2019 at 17:21
Download
Circular1-15.stl
363.56 kB -
05/25/2019 at 17:21
Download
UpperMount1-15.stl
305.16 kB -
05/25/2019 at 17:21
Download
LowerMount1-15.stl
376.64 kB -
05/25/2019 at 17:21
Download
UpperCircular1-15.stl
298.03 kB -
05/25/2019 at 17:21
Download
HarmonicDrive1-31.stp
.step file for intergration.
stp -
18.28 MB -
05/20/2019 at 17:09
Download
FlexSpline.stl
Printing with a printer that has X/Y resolution of 100 micron, ideally in nylon or a flexible filament (but not too soft).
1.53 MB -
05/15/2019 at 18:09
Download
Cicular.stl
Printing with a printer that has X/Y resolution of 100 micron, ideally in nylon.
1.14 MB -
05/15/2019 at 18:08
Download
UpperMount.stl
Printing with high infill (>= 80%).
274.69 kB -
05/15/2019 at 18:08
Download
UpperCover.stl
298.91 kB -
05/15/2019 at 18:08
Download
EllipseDrive.stl
Printing with a printer that has X/Y resolution of 100 micron. Scale down or up a little bit depending on you printer and the fitting on the flex spline.
590.71 kB -
05/15/2019 at 18:08
Download
LowerMount.stl
363.66 kB -
05/15/2019 at 18:08
Download
LowerCircular.stl
328.70 kB -
05/15/2019 at 18:08
Download
HubAdapter635mm.stl
Adapter for Nema 23 motor of shaft 6.35 mm.
330.45 kB -
05/15/2019 at 18:08
Download
