Upload the stl and step files for 1:15 and 1:21 design
05/25/2019 at 17:29 • 0 commentsSorry for the incomplete upload.
Add this project to the 6 axis robot project.
05/21/2019 at 19:22 • 0 comments6 axis robot project: https://hackaday.io/project/165680-3d-printable-6-axis-robot-dauphine
.step file updated
05/20/2019 at 17:11 • 0 commentsUploaded the assembly .step file for application integration.
Changelog
05/19/2019 at 03:44 • 0 commentsVersion 1.0 used a Deep Grove Ball Bearing instead of a Cross Roller Bearing. I just want to see how good the gear teeth meshed with each other.
This is the tooth template I used. It's a double arc profile for additional rigidity of the flex spline.
*Source: https://www.harmonicdrive.net/technology/harmonicdrive
And the meshing analysis:
Leo Vu
