1Source All Required Components
Download the Bill Of Materials from the github repository at https://github.com/td0g/high_speed_flash/blob/master/BOM%201.1.csv
Purchase all the hardware listed. Components purchased from eBay / Alibaba / Bangood require several weeks shipping time. You may want to get started on assembly before all components have arrived.
2Prepare the Tools
Be sure to have the following tools ready:
- 3D printer with 200mm x 200mm bed
- Soldering iron & solder
- Small side cutters
- Hot glue gun
- Allen wrenches
- Dupont crimper kit (optional but recommended)
3Follow the Steps in the Edgerton Assembly Manual
Download the Edgerton Assembly Manual from the Github repository at https://github.com/td0g/high_speed_flash/blob/master/Assembly%20Manual%201.1.pdf
Follow all the steps outlined in the manual.
Tyler Gerritsen
This looks very interesting, I have built 4 air gap flashes before, but with age have got rather frightened of them. I would like to build this with a circuit boarb rather that perth. any problem with that, what should the board dimentions be. Thanks
