This years version uses the following components:
- Main PCB is 58mm x 58mm
- A Tenergy 3.7V 800mAh Lithium-Ion 14500 battery (essentially a AA sized lithium cell)
- The fairly new WS2812C-2020 LED module, which is the 5mA variant. There are 66 of these per pendant.
- An ATSAMD51G18A which is a Cortex-4MF MCU with 256KB of flash memory.
- A Ti BQ25895 as the PMIC for the LiPo battery.
- A SX1280 radio chip for communication.
- A I2C 0.69 inch 96x16 OLED b/w display (ER-OLED0.69-1W)
- Two FETs to turn the LEDs on and off
- A off branch 3.3V LDO regulator
- 1x main switch
- 3x tactile buttons
- Lots of passives, all 0603 parts
- M2 nylon bolts, nuts and washers as spacers
- Laser cut acrylic cover/diffuser.
- A 2.4Ghz tuned WiFi antenna.
Tinic Uro
So where to get them? Pretty much the only choice is AliExpress. When you search for 'WS2812C-2020' you get a bunch of vendors, but most of them only sell in hundreds. What I needed were full reels. The best way I found is to contact the seller and ask for a full reel and price quote. A full reel has 4500 modules, I got two for $313.93 each to the door shipped with DHL. Quite affordable at 7cents for each LED module IMO. Now, there is a certain risk with these vendors: last year someone cut open my package (probably deliberately) in transit and I lost a full reel of APA102-2020s... No recourse, no matter how hard I tried since they "correctly" claimed the package arrived at my place. There was just nothing in it anymore. Anyway, I have the reels in my hands:
Ben Lim
Matthias
morgan
Using that 14500 cell is a neat tip. But I'm having trouble grasping the scale of that cell versus the badge itself. Do you have any images with the cell installed in the badge?
