1Step - 1 : Collect all necessary component
You can find component list in component list section
2Step - 2 : Connection all componet
Connect all component according to this diagram. You will need a good quality soldering iron to connect all together.
3Step - 3 : Connect Programmer
To upload code in Arduino Pro Mini you will need a FTDI adapter or another arduino as programmer. (This image has been taken from Arduino Website)
4Step - 4 : Upload Code
Open arduino ide and select board as arduino pro mini. also select correct com port and upload following code.
/* Project : Obstacle Detector for Blind/Visually Impaired People by Cybernetics Robo Academy https://www.cyberneticsroboacademy.com Credit : Syed Razwanul Haque(Nabil), CTO, Cybernetics Robo Academy nabil@cruxbd.com Orpon Chanda and Nihal , Student, Cybernetics Robo Academy Cybernetics Robo Academy is a Institute under Cybernetics Robo Limited Library Used : https://github.com/pololu/vl53l0x-arduino The range readings are in units of mm. */ int vibratorPin = 13; #include <Wire.h> #include <VL53L0X.h> VL53L0X sensor; void setup() { Wire.begin(); pinMode(vibratorPin, OUTPUT); sensor.init(); sensor.setTimeout(2000); // Start continuous back-to-back mode (take readings as // fast as possible). To use continuous timed mode // instead, provide a desired inter-measurement period in // ms (e.g. sensor.startContinuous(100)). sensor.startContinuous(); } void loop() { int val = sensor.readRangeContinuousMillimeters(); Serial.print(val); if (sensor.timeoutOccurred()) { Serial.print(" TIMEOUT"); } else if (sensor.readRangeContinuousMillimeters() < 450) { digitalWrite(vibratorPin, HIGH); } else { digitalWrite(vibratorPin, LOW); } } -
5Step - 4 : Insert everything in glove
Carefully insert in glove. Different glove need different technique to insert. If you use a bicycle glove you can insert arduino and all other component user its plastic protection. See this picture for an idea.
Make sure sensor is in correct position. Make a square space for on/off switch.
6Step - 5: Final Step
Now check whether everything is working. Finally try to give it to visually impaired people and take feedback from them to further improvement.
Syed Razwanul Haque Nabil
