Important note: Full documentation and changelog are maintained on Github: https://github.com/vd-rd/hw_cape_gsm Open hardware module for providing communications support via GPRS to embedded projects. The module can use any 2G network operating in the 850/900MHz or 1800/1900MHz spectrum. The modem features an audio link for voice calls and a TCP/IP stack for data transfer. Features: MicroSIM connector 3.5mm jack with microphone status LED indicator two serial ports ( ATcommands on main serial port and support for daisy chaining a second UART device) standard u.FL connector for antenna standard ApolloIoT expansion header
a. How to add built-in GSM module of Orange Pi 2g IoT board in asterisk, so that A GSM trunk call/text can be transferred on SIP extension. I know chan-dongle, but asterisk is not detecting GSM module. I ahve tried different versions of asterisk.
Hi,
I am making Asterisk PBX over Orange Pi - 2g IoT, using standard Ubuntu Server 16.4 available on Orange-Pi website (http://www.orangepi.org/downloadresources/orangepi2G-IoT/orangepi2G-IoT_b0408713aa11652927416.html). Everything is working fine, but I am stuck on two issues,
b. How to change IMEI of Orange Pi 2g IoT
Looking for solutions
Regards
