Hackaday.io Hackaday.io
Sign up Log in
DISCRETE BCD Counter
Here I made a digital counter using discrete transistors.
discrete-electronics-guyDiscrete Electronics Guy
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3 comments
2 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 3
  • Hackaday Prize 2019
View Gallery
710
3
2
2
Team (1)
  • discrete-electronics-guyDiscrete Electronics Guy
Join this project's team
  • Instructables
  • Blog (about BCD counter)
  • Blog, ( about T f-f)
completed project
hardware
2019hackadayprize digital counter bcd counter discrete counter counter using transistors 4 bit counter digital up counter counter design
This project is submitted for
This project was created on 05/25/2019 and last updated 7 years ago.
Description
Here I made a digital counter using discrete transistors. Also use some resistors, capacitors, etc... The counter is an interesting machine which count numbers. Here it is a 4 BIT binary counter. So it count from 0000 binary number to 1111 binary number. In decimal it is from 0 to 15. After this I convert it into a BCD counter. The BCD counter is a counter which count upto 1001(9 decimal). So it reset to 0000 after counting 1001 number. For this function, I add some combination circuit to it. OK.For more details about this counter theory visit my BLOG : https://0creativeengineering0.blogspot.com/2019/03/4-bit-counter-using-discrete-transistor.htmlHere I made this circuit by using T flip-flops. IFor more details about T flip-flop please visit my Blog which is about it.
Details
Log In/Sign up to comment
Sign up with Github
OR
Discrete Electronics Guy wrote 05/25/2019 at 08:57 • point
No... that is because. When connecting leds to the Q', the voltages at its collector is drops which due to the small collector current design. I design  collector current keeps low as possible to decrease the whole circuit current consumption.
Ken Yap wrote 05/25/2019 at 09:22 • point
You are going to consume current when the LED is on anyway, so that makes no difference. The change just makes the Q' do double duty. In fact you should parallel the LED and current limiting resistor with the same resistor as the Q transistor so that the Q' collector is pulled to high level. The difference when on due to the LED current is only around 0.1V. And what's a few mA for what is a pedagogical circuit.
Ken Yap wrote 05/25/2019 at 08:52 • point
You could have saved a few transistors by using the Q' transistors to sink the LED indicators' current.
This is a discreet four bit adder I designed and constructed using 60 RTL NAND gates.
Project Owner Contributor
Discreet Four Bit Adder
curtis-bucherCurtis Bucher
An 8-states Turing machine with 2 tapes, made using basic electronic components
A two tapes Turing machine
olivier-bailleuxOlivier Bailleux
A fluidic logic system in which siphons are the basic functional elements. It doesn't require continuous flows of liquid - hence static.
Siphon-based static fluidic logic
willstevenswill.stevens
Unusual use of digital logic gate as a 3-bit linear or non-linear DAC
3-bit Resistorless Dac Using CD4572UB
adrian-freedAdrian Freed
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "DISCRETE BCD Counter", please tell us the reason.
Send message
Remove Member
