PushButton STLs.zip
Printable Case - Includes STLs and 3MF files for some parts The "Case Front.stl" has two options for the LED lenses. For single extruder you can print "Case Front.stl" and then 4x "Lens - Push Fit.stl" and insert them manually. If you have access to a multi-extruder printer then you can use "Lens - Print In Place.stl" to have them printed together.
application/x-zip-compressed -
331.75 kB -
06/16/2020 at 08:24
