Usb WiFI temerature sensor
Sensor as no case solution
Have you ever tried to find a case for your device? And if you need a case with a power supply? Which plug directly into an electrical outlet?
How nice that we all have a magic box for unnecessary phone chargers!
Voila! Now we have a temperature sensor, which we can easily plug into any outlet in our house!
It will be just as easy for you to reprogram this device - the USB port serves not only for powering but also for programming this module.
Tom Nardi wrote 06/04/2019 at 17:53 point
What temperature sensor are you using? Is it something that can report humidity as well, like the BME280? I could see these being very useful as distributed indoor environmental sensor nodes.
Muhomor wrote 06/04/2019 at 18:05 point
I used bmp280.  I only needed the temperature, and next reason i could buy only this one.  Thank you for your opinion!
