Sensor as no case solution
What temperature sensor are you using? Is it something that can report humidity as well, like the BME280? I could see these being very useful as distributed indoor environmental sensor nodes.
I used bmp280. I only needed the temperature, and next reason i could buy only this one. Thank you for your opinion!
CarbonCycle
MatYay
mircemk
Miguel Tomas
Yes, delete it Cancel
You are about to report the project "Usb WiFI temerature sensor", please tell us the reason.
