Project Albatross
Back to overview
Subsurface Data Acquisition using Semi-Autonomous Aquatic Robotics
seachanged wrote 08/15/2020 at 19:37 point
Fantastic build, well and satisfyingly documented. Congratulations!
"This power would be a 24 V signal capable of drawing up to 3 A, potentially. However, based on our experience and on some online research, the 26 AWG wire in the Blue Robotics tether could carry a maximum current of 1 A safely."
A boost converter on the surface and buck converter underwater might be a candidate for this solution. Cooling might have been a problem, but perhaps some other constraint might have ruled this solution out?
"To make the plot generation real-time while not wasting resources,..."
A resource that is not used is wasted. What was the limiting resource?
