A new challenger appears
07/03/2019 at 21:13 • 0 commentshttps://www.electromate.com/assets/catalog-library/pdfs/netzer-precision/Netzer_DS-90-64-3SH-Specsheet.pdf
18 bits precision 50mm ID bore absolute encoder. No price listed. -
one suggestion
06/23/2019 at 03:11 • 0 commentshttps://ams.com/as5311#tab/description
Oskar from ODrive suggested the AS5311 linear magnetic encoder paired to a 128-pole magnetic ring. In theory this is 262411 positions (19 bits), because it's a 12 bit sensor * 8 bits for each pole. Unfortunately it's a relative encoder, so it's missing that critical absolute positioning I need.
On the other hand, it's only ~$15 USD. So if you're reading this and relative is enough for you... thank Oskar. -
Analog example
06/10/2019 at 19:23 • 0 commentsThanks to @Simon Merrett for pointing me at this great analog example from Japan.
