Free Breakout Board with Purchase of Joystick!
07/22/2019 at 04:16 • 0 comments -
Joystick and Breakout Now Available!
07/18/2019 at 17:17 • 0 commentsB.G.Micro now has both the Breakout Board and original IBM PCjr Joystick in stock! The joysticks are manufactured by Kraft and with the exception of the connector are the same joysticks available for Apple ][, Tandy Color Computer, and many more! This breakout board lets you experiment with interfacing to the joystick without cutting off the cable end. you can create adapters to other computers or interface to an Arduino!
Attention Hackers: Free Hardware!
06/08/2019 at 19:17 • 0 commentsHey Hackers! I have a limited amount of free hardware for developers who are interested in hacking around with a classic analog joystick! If you are interested in getting this thing working with Arduino, some old school CPU, or hacking into a retro PC, I'll send you some free hardware as long as you post the info as a hackaday.io project! one example of a project would be to get this joystick working with the arduino library project documented here: https://www.instructables.com/id/Arduino-LeonardoMicro-as-Game-ControllerJoystick/
email me at danders.dev@gmail.com if you are interested!
