Hackaday.io Hackaday.io
Sign up Log in
Triple Cycloidal Robot Arm
3D printed four Joint Robot Arm. Three of these joints have triple cycloidal gearboxes with 30:1 ratio powered by NEMA 17 stepper motors
paul-gouldPaul Gould
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
7.3k views
5 comments
102 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 4
    • View all
  • Instructions 0
  • Discussion 5
View Gallery
Public Chat
7.3k
5
102
53
Team (1)
  • paul-gouldPaul Gould
Join this project's team
  • thingiverse
  • youtube
ongoing project
robot arm cycloidal ROBOT Stepper motor
Related lists
ZYQ_IO
my test using
This project was created on 06/18/2019 and last updated 5 years ago.
Description
https://www.thingiverse.com/thing:3699096
Project Status.Bearings are on orderParts are 3D printingThe design is in a constant state of flux
Project Logs
Collapse
  • Robot Arm Wrists
    Paul Gould • 06/27/2021 at 10:45 • 0 comments
  • Inline Timing Belt reduction with internal NEMA17
    Paul Gould • 04/25/2021 at 12:36 • 0 comments
  • Open Source Cycloidal Actuator with NEMA17
    Paul Gould • 04/05/2021 at 14:16 • 0 comments
  • NEMA17 Dual Stage Timing Belt Reduction
    Paul Gould • 04/04/2021 at 15:34 • 0 comments
View all 4 project logs
Log In/Sign up to comment
Sign up with Github
OR
Jin Han wrote 07/17/2019 at 23:36 • point
haha I was considering splitting one rotor thinner and placing them on each side of the thick rotors too! how did you find this method? any improvements on vibration?
Paul Gould wrote 07/18/2019 at 13:43 • point
It is so much better, less twist.  Check out the YouTube video. https://www.youtube.com/watch?v=pizl7i-uB68
https://github.com/gouldpa/Triple-Cycloidal-Robot-Arm-Proto-2
Matt Balisky wrote 06/21/2019 at 06:40 • point
Hey Paul, I am currently creating a robotic arm for a design competition at my university and was wondering where you found the information on the design of the cycloidal gears?  Additionally would it be possible to upload the assembly so that I could open it in solidworks? currently it is just a 3D object file which doesn't allow me to dissemble it at all.
Paul Gould wrote 06/26/2019 at 17:12 • point
https://hackaday.io/project/163766-low-cost-3d-printed-robot-tail/log/159482-gear-box-design
I'm using Autodesk inventor. What is a good format to used between this and your solidworks? Is step ok?
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Triple Cycloidal Robot Arm", please tell us the reason.
Send message
Remove Member
