Quick update
03/31/2026 at 11:35 • 0 commentsSince someone had problems following my VR2 hardware setup:
I changed the interface to not use a diode, but a 470 Ohm resistor instead! The code takes care of letting the lines float at the right moment, so bi-directional communication is working over 1 wire.
Bernhard "HotKey" Slawik
