Fallout Shelter - Atomic Pi Enclosure
OpenSCAD scripts to print a customizable enclosure for the Atomic Pi single board computer.
tmTM
A new home for your Atomic Pi (based on a Raspberry Pi enclosure from another project: https://hackaday.io/project/160052-voicebox).
Atomic.scad
Main script to generate the case components.
scad - 10.27 kB - 06/29/2019 at 23:41
Download
AtomicBoard.scad
Script to generate a dummy Atomic Pi board for visualization.
scad - 2.10 kB - 06/29/2019 at 23:41
Download
Utilities.scad
Positioning utilities, etc.
scad - 4.56 kB - 06/29/2019 at 23:41
Download
Cone.stl
Standard Tesselated Geometry - 975.31 kB - 06/29/2019 at 23:41
Download
Grill.stl
Standard Tesselated Geometry - 310.54 kB - 06/29/2019 at 23:41
Download
View all 12 files
  • Showing My Power Level
    TM06/30/2019 at 00:20 0 comments
    The first step before fixing the parameters of your Atomic Pi enclosure is to find a way to power it. The mini board by Digital Loggers is a pain to fit into a box, so I made my own board from a RadioShack(?) prototype board and some spare headers.
    The +5V and GND headers to the right are to power the cooling fan. I'm using a 50mm 12V DC fan from my junk box. It seems to run fine on +5V. The blue headers are power in: +12V, GND, GND, +5V.
    (I'm not using a +12V supply as it's easier to just plug a USB sound card into an external USB hub.)
    I only wired up the most easily accessible GPIO pins (from bottom right, GPIO2/0/5/3), and skipped the serial pins as the board was getting too messy. (If I ever need more than 4 GPIOs I'll add some wires.)
    Any prototype board will do, as long as it has 13 rows of holes (if you want to breakout the full 26 pin header.)
View project log
Rich text editor
qi4u wrote 08/01/2019 at 03:30 point
I joined because of this project with the atomic pi. i want to build a power supply and case like these soon
